CartesianMeshTrimmer
This CartesianMeshTrimmer object performs peripheral and/or across-center (0, 0, 0) trimming for assembly or core 2D meshes generated by PatternedCartesianMG.
Overview
The CartesianMeshTrimmer object takes the square mesh generated by PatternedCartesianMeshGenerator as "input" and trims off part of the mesh. The input mesh can also be PatternedCartesianMeshGenerator's output processed by PeripheralRingMeshGenerator or PatternedCartesianPeripheralModifier.
Two types of trimming can be performed by CartesianMeshTrimmer: Peripheral Trimming and Through-the-Center Trimming, which will be introduced separately as follows.
A schematic drawing showing different trimming schemes for a cartesian mesh.
Figure 1: A schematic drawing showing different trimming schemes for a cartesian mesh.
Peripheral Trimming
Peripheral trimming trims off peripheral region(s) of one or multiple sides of the input square assembly mesh. To be specific, for each side, half of the unit pin meshes are trimmed off, as shown by the purple lines in Figure 1. Each side of the square assembly is assigned an index as illustrated in Figure 1. Users can use "trim_peripheral_region" to set which sides need to be trimmed off (1) and which need to be retained (0). The setting "trim_peripheral_region" = "1 1 1 1" trims off all the sides (full peripheral trimming) to create a square assembly mesh with half-pins on each of the external 4 boundaries. Partial peripheral trimming may be employed for practical applications to create peripheral assemblies in a core whose normal interior assembly units contain half-pins on the boundary. The mesh metadata generated by PatternedCartesianMeshGenerator are retained, with pattern_pitch_meta updated to take trimming into consideration. The output of this object can be assembled into a patterned lattice using PatternedCartesianMeshGenerator.
Center Trimming
Center trimming removes azimuthal sectors from the input square assembly or core mesh. The mesh may be trimmed along lines of symmetry in the input mesh. Only certain square meshes are eligible to be trimmed by this object due to imposed symmetries (see Trimmability). Valid square input meshes may be trimmed at eight possible center trimming lines, indexed from 0 to 7 as the blue lines shown in Figure 1. Each unit azimuthal sector is 45. A practical application of center trimming is to reduce the domain size (and simulation scale) by leveraging symmetry through reflected boundary conditions. Therefore the largest possible output mesh after center trimming contains four consecutive azimuthal sectors (i.e., half of the input mesh), while the smallest possible output mesh has only one azimuthal sector (i.e., one eighth of the input mesh). This mesh trimmer object RETAINS any sectors which are included between the trimming line defined by "center_trim_starting_index" to the trimming line defined by "center_trim_ending_index" swept out in a counterclockwise direction. Other sectors are discarded.
Trimmability
In general, CartesianMeshTrimmer trims meshes generated by PatternedCartesianMeshGenerator. An assembly mesh consisting of patterned pin meshes has both peripheral and center trimmability; whereas a core mesh consisting of patterned assembly meshes only has center trimmability. Two mesh metadata entries (peripheral_trimmability and center_trimmability) are created by PatternedCartesianMeshGenerator to tell CartesianMeshTrimmer which trimming options are valid. In the absence of these two meta data, CartesianMeshTrimmer will throw an incompatible error message.
In addition, PeripheralRingMeshGenerator, which applies quadrilateral peripheral cylinder mesh around an assembly or core, retain these two mesh meta data from the input mesh so that valid meshes generated by PeripheralRingMeshGenerator may also be trimmed. Similarly, assembly meshes modified by PatternedCartesianPeripheralModifier also have these meta data retained and are thus able to be trimmed by this generator.
Degenerate Quadrilateral Elements
When trimming a mesh, some elements may be located across the trimming line and thus need to be processed to ensure a smooth trimming boundary. Generic tools such as PlaneDeletionGenerator is capable of trimming meshes but leaves a zigzag trimming boundary in the presence of across-trimming-line elements.
To avoid this zig-zag boundary, CartesianMeshTrimmer adopts a post-trimming processing algorithm to smooth the trimming boundary. The algorithm moves the nodes of the across-trimming-line elements in the normal direction of the trimming line onto the trimming line. During this procedure, some elements may become zero volume and will be removed. More importantly, after node moving, some quadrilateral elements may have three co-linear vertices on the trimming line, which make the element degenerate. To fix this issue, these degenerate quadrilateral elements are converted into triangular elements. As triangular elements and quadrilateral elements cannot share a single subdomain id/name, new subdomains are created for any affected quadrilateral element subdomains. The subdomain ids of the new subdomains are decided by shifting the original subdomain ids by "tri_elem_subdomain_shift" (default shift value is the maximum subdomain id of the mesh), while the subdomain names of the new subdomains are created by appending "tri_elem_subdomain_name_suffix" after the original subdomain names.
Boundary Assignment
For peripheral trimming, the new boundary formed by the trimming operation is the new external boundary. Therefore, the boundary id defined by "external_boundary" is assigned to the new boundary. On the other hand, for center trimming, the new boundary formed by the trimming operation is a mirror boundary instead of an external boundary. Hence, the boundary id defined by "external_boundary" is NOT assigned to the new boundaries.
In addition, users can optionally use "peripheral_trimming_section_boundary" and "center_trimming_section_boundary" to assign additional boundary names to the new boundary.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [trim_0]
    type = CartesianMeshTrimmer<<<{"description": "This CartesianMeshTrimmer object performs peripheral and/or across-center (0, 0, 0) trimming for assembly or core 2D meshes generated by PatternedCartesianMG.", "href": "CartesianMeshTrimmer.html"}>>>
    input<<<{"description": "The input mesh that needs to be trimmed."}>>> = pattern
    trim_peripheral_region<<<{"description": "Whether the peripheral region on each of the four sides will be trimmed in an assembly mesh. See documentation for numbering convention."}>>> = '1 1 1 1'
    peripheral_trimming_section_boundary<<<{"description": "Boundary formed by peripheral trimming."}>>> = peripheral_section
(contrib/moose/modules/reactor/test/tests/meshgenerators/cartesian_mesh_trimmer/patterned_trimmed.i)
Input Parameters
  • inputThe input mesh that needs to be trimmed.
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:The input mesh that needs to be trimmed.
Required Parameters
  • external_boundaryExternal boundary of the input mesh prior to the trimming.
    C++ Type:BoundaryName
    Controllable:No
    Description:External boundary of the input mesh prior to the trimming.
Optional Parameters
  • center_trim_ending_indexIndex of the ending center trimming position.
    C++ Type:short
    Range:center_trim_ending_index>=0 & center_trim_ending_index<12
    Controllable:No
    Description:Index of the ending center trimming position.
  • center_trim_starting_indexIndex of the starting center trimming position.
    C++ Type:short
    Range:center_trim_starting_index>=0 & center_trim_starting_index<12
    Controllable:No
    Description:Index of the starting center trimming position.
  • center_trimming_section_boundaryBoundary formed by center trimming (external_boundary will be assigned if this parameter is not provided).
    Controllable:No
    Description:Boundary formed by center trimming (external_boundary will be assigned if this parameter is not provided).
Center Trimming Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
  • peripheral_trimming_section_boundaryBoundary formed by peripheral trimming.
    Controllable:No
    Description:Boundary formed by peripheral trimming.
  • trim_peripheral_region0 0 0 0 Whether the peripheral region on each of the four sides will be trimmed in an assembly mesh. See documentation for numbering convention.
    Default:0 0 0 0
    C++ Type:std::vector<unsigned short>
    Range:trim_peripheral_region<=1
    Controllable:No
    Description:Whether the peripheral region on each of the four sides will be trimmed in an assembly mesh. See documentation for numbering convention.
Peripheral Trimming Parameters
  • tri_elem_subdomain_name_suffixtrimmer_triSuffix to the block name used for quad elements that are trimmed/converted into triangular elements to avert degenerate quad elements
    Default:trimmer_tri
    C++ Type:SubdomainName
    Controllable:No
    Description:Suffix to the block name used for quad elements that are trimmed/converted into triangular elements to avert degenerate quad elements
  • tri_elem_subdomain_shiftCustomized id shift to define subdomain ids of the converted triangular elements.
    C++ Type:unsigned short
    Controllable:No
    Description:Customized id shift to define subdomain ids of the converted triangular elements.
Trimmed Boundary Repair Parameters
