PeripheralRingMeshGenerator
This PeripheralRingMeshGenerator object adds a circular peripheral region to the input mesh.
Overview
The PeripheralRingMeshGenerator object adds a 2D peripheral region using either first-order or second-order quadrilateral elements (i.e., QUAD4 or QUAD9) with a circular external boundary to the input 2D mesh. The order of the elements is automatically determined by the order of the input mesh elements on its external boundary. Mixed element order is NOT supported. A common use of this mesh generator is to mesh the circular peripheral region of a reactor core. This mesh generator can be used recursively on a mesh to add as many rings of peripheral regions as desired.
More Information
The use of this mesh generator requires an input mesh defined by "input" and the name/ID of its external boundary defined by "input_mesh_external_boundary". PeripheralRingMeshGenerator examines the external boundary of the input mesh to confirm whether the algorithm will function properly for the given external boundary. Trivially, the external boundary of the input mesh must be a single-segment closed loop.
This object then calculates the azimuthal angles of all the nodes on the external boundary of the input mesh. Each node on the input mesh external boundary is then used as the start point of a line segment, whose end point (node) lies on the circle defined by "peripheral_ring_radius". The segment is therefore aligned along the same azimuthal angle as the start point. Intermediate nodes may also be added if "peripheral_layer_num" is greater than unity. Currently, the algorithm only works when the azimuthal angles of the boundary nodes change monotonically as the external boundary is traversed. This object always generates a peripheral ring with its center at the origin, no matter where the centroid of the "input" mesh is. Optionally, "force_input_centroid_as_center" can be set as true to move the centroid of the "input" mesh to the origin.
The added peripheral block must be assigned an ID given by "peripheral_ring_block_id" along with an optional name given by "peripheral_ring_block_name". The new external boundary of the mesh can also be assigned an ID and a name through "external_boundary_id" and "external_boundary_name", respectively.
Optionally, users can preserve the volume of the peripheral ring region by setting "preserve_volumes" as true to enable correction of polygonization effect.
The peripheral block (in teal) created by this mesh generator using the input shown in Example Syntax section.
Figure 1: The peripheral block (in teal) created by this mesh generator using the input shown in Example Syntax section.
In addition, the radial meshing density of the peripheral ring region can be biased by setting the "peripheral_radial_bias" parameter. The bias value should be a positive Real type parameter, which is the radial dimension ratio between two radially-neighboring elements (outer to inner).
Aside from the general mesh radial biasing options described above, users can also define boundary layers within the peripheral ring region. Both inner and outer boundary layers are supported. Each boundary layer has three key parameters that need to be provided:
The peripheral block (in teal) created by this mesh generator with biased boundary layers.
Figure 2: The peripheral block (in teal) created by this mesh generator with biased boundary layers.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [pr]
    type = PeripheralRingMeshGenerator<<<{"description": "This PeripheralRingMeshGenerator object adds a circular peripheral region to the input mesh.", "href": "PeripheralRingMeshGenerator.html"}>>>
    input<<<{"description": "The input mesh to be modified."}>>> = fmg
    peripheral_layer_num<<<{"description": "The radial layers of the peripheral ring to be added."}>>> = 3
    peripheral_ring_radius<<<{"description": "Radius of the peripheral ring to be added."}>>> = 80.0
    input_mesh_external_boundary<<<{"description": "The external boundary of the input mesh."}>>> = 10000
    peripheral_ring_block_id<<<{"description": "The block id assigned to the created peripheral layer."}>>> = 250
    peripheral_ring_block_name<<<{"description": "The block name assigned to the created peripheral layer."}>>> = reactor_ring
(contrib/moose/modules/reactor/test/tests/meshgenerators/peripheral_ring_mesh_generator/core_ring.i)
Input Parameters
  • inputThe input mesh to be modified.
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:The input mesh to be modified.
  • input_mesh_external_boundaryThe external boundary of the input mesh.
    C++ Type:BoundaryName
    Controllable:No
    Description:The external boundary of the input mesh.
  • peripheral_ring_block_idThe block id assigned to the created peripheral layer.
    C++ Type:unsigned short
    Controllable:No
    Description:The block id assigned to the created peripheral layer.
  • peripheral_ring_radiusRadius of the peripheral ring to be added.
    C++ Type:double
    Unit:(no unit assumed)
    Range:peripheral_ring_radius>0
    Controllable:No
    Description:Radius of the peripheral ring to be added.
Required Parameters
  • external_boundary_idOptional customized external boundary id.
    C++ Type:short
    Range:external_boundary_id>0
    Controllable:No
    Description:Optional customized external boundary id.
  • external_boundary_nameOptional customized external boundary name.
    Controllable:No
    Description:Optional customized external boundary name.
  • force_input_centroid_as_centerFalseWhether to enforce use of the centroid position of the input mesh as the center of the peripheral ring by translating the input mesh to the origin.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether to enforce use of the centroid position of the input mesh as the center of the peripheral ring by translating the input mesh to the origin.
  • peripheral_layer_num3The radial layers of the peripheral ring to be added.
    Default:3
    C++ Type:unsigned int
    Range:peripheral_layer_num>0
    Controllable:No
    Description:The radial layers of the peripheral ring to be added.
  • peripheral_ring_block_nameThe block name assigned to the created peripheral layer.
    C++ Type:SubdomainName
    Controllable:No
    Description:The block name assigned to the created peripheral layer.
  • preserve_volumesTrueWhether the volume of the peripheral region is preserved by fixing the radius.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Whether the volume of the peripheral region is preserved by fixing the radius.
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
  • peripheral_inner_boundary_layer_bias1Growth factor used for mesh biasing of the peripheral ring inner boundary layer.
    Default:1
    C++ Type:double
    Range:peripheral_inner_boundary_layer_bias>0
    Controllable:No
    Description:Growth factor used for mesh biasing of the peripheral ring inner boundary layer.
  • peripheral_inner_boundary_layer_intervals1Number of radial intervals of the peripheral ring inner boundary layer
    Default:1
    Range:peripheral_inner_boundary_layer_intervals>0
    Controllable:No
    Description:Number of radial intervals of the peripheral ring inner boundary layer
  • peripheral_inner_boundary_layer_width0Width of peripheral ring region that is assigned to be the inner boundary layer.
    Default:0
    C++ Type:double
    Range:peripheral_inner_boundary_layer_width>=0
    Controllable:No
    Description:Width of peripheral ring region that is assigned to be the inner boundary layer.
  • peripheral_outer_boundary_layer_bias1Growth factor used for mesh biasing of the peripheral ring outer boundary layer.
    Default:1
    C++ Type:double
    Range:peripheral_outer_boundary_layer_bias>0
    Controllable:No
    Description:Growth factor used for mesh biasing of the peripheral ring outer boundary layer.
  • peripheral_outer_boundary_layer_intervals1Number of radial intervals of the peripheral ring outer boundary layer
    Default:1
    Range:peripheral_outer_boundary_layer_intervals>0
    Controllable:No
    Description:Number of radial intervals of the peripheral ring outer boundary layer
  • peripheral_outer_boundary_layer_width0Width of peripheral ring region that is assigned to be the outer boundary layer.
    Default:0
    C++ Type:double
    Range:peripheral_outer_boundary_layer_width>=0
    Controllable:No
    Description:Width of peripheral ring region that is assigned to be the outer boundary layer.
  • peripheral_radial_bias1Value used to create biasing in radial meshing for peripheral ring region.
    Default:1
    C++ Type:double
    Range:peripheral_radial_bias>0
    Controllable:No
    Description:Value used to create biasing in radial meshing for peripheral ring region.
Mesh Boundary Layer And Biasing Options Parameters
