How to Contribute
Cardinal is a collaborative effort, and we encourage and welcome new contributions.
Before investing time in adding a new feature, it is recommended that you discuss with the community and developer team about your contribution. An early discussion can help ensure compatibility with Cardinal's standards for code modularity, documentation, testing, and integration with larger systems in MOOSE, NekRS, and OpenMC. To start a discussion, please visit the Discussions page.
Work in a Fork
The first step is modifying Cardinal is to create your own fork where you can create branches and commit your set of changes.
1. Fork Cardinal
Navigate to the Cardinal repository
Click the "Fork" icon in the upper right
Clone your fork to your local machine; below, replace
username
with your GitHub username or the account where you forked the repository to
2. Add the upstream
Remote:
Add the real Cardinal repository as a remote named "upstream":
You should now have at least two remotes when you run git remote -vv
3. Make Modifications
To make modifications to Cardinal, first create a branch where you will commit your work.
Then, add your contributions to the branch.
Before contributing your changes, you should rebase them on top of the latest upstream "devel" branch in the real Cardinal repository:
4. Add Documentation
Cardinal uses MooseDocs for documentation. Please be sure to document your changes and commit it to your working branch.
5. Push Modifications to GitHub
Push your branch to your fork:
6. Create a Pull Request
Open a pull request in the main Cardinal repository to merge from your fork (the working branch, branch_name
that we have been working on) into the devel
branch of the main repository. For help with pull requests, please consult the GitHub documentation.
When you open a pull request, please assign a Cardinal developer to review it. They may have suggestions for changes; you can add changes again locally in your branch, with new commits. Then, simply push to your fork with git push origin branch_name
; this will automatically reflect in the pull request you have opened in the main Cardinal repository.
