- inputThe mesh we want to modify
C++ Type:MeshGeneratorName
Unit:(no unit assumed)
Controllable:No
Description:The mesh we want to modify
- normalThe normal that defines the plane
C++ Type:libMesh::VectorValue<double>
Controllable:No
Description:The normal that defines the plane
- pointThe point that defines the plane
C++ Type:libMesh::Point
Controllable:No
Description:The point that defines the plane
PlaneDeletionGenerator
Removes elements lying 'above' the plane (in the direction of the normal).
Overview
Allows for deletion of elements that lie on one side of a plane. The plane can be specified via a point and a vector that is normal to the plane. All elements whose centroids lie "above" (in the direction of the normal vector) the plane will be removed from the mesh.
An optional new_boundary
parameter can also be specified which will make any newly-created free-surfaces have that boundary ID.
Example
The Original Mesh
With the elements removed (and showing the new boundary)
Input Parameters
- delete_exteriorsTrueWhether to delete lower-d elements whose interior parents are deleted
Default:True
C++ Type:bool
Controllable:No
Description:Whether to delete lower-d elements whose interior parents are deleted
- new_boundaryoptional boundary name to assign to the cut surface
C++ Type:BoundaryName
Controllable:No
Description:optional boundary name to assign to the cut surface
Optional Parameters
- control_tagsAdds user-defined labels for accessing object parameters via control logic.
C++ Type:std::vector<std::string>
Controllable:No
Description:Adds user-defined labels for accessing object parameters via control logic.
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
