- square_sizeSize (side length) of the square mesh to be generated.
C++ Type:double
Unit:(no unit assumed)
Range:square_size>0.0
Controllable:No
Description:Size (side length) of the square mesh to be generated.
CartesianConcentricCircleAdaptiveBoundaryMeshGenerator
This CartesianConcentricCircleAdaptiveBoundaryMeshGenerator object is designed to generate square meshes with adaptive boundary to facilitate stitching.
Overview
The CartesianConcentricCircleAdaptiveBoundaryMeshGenerator object generates a 2D mesh for concentric circles with a square enclosure with or without external ducts. It is similar to PolygonConcentricCircleMeshGenerator and the majority of the parameters and functionalities of this object are described in the documentation of PolygonConcentricCircleMeshGenerator. The major unique feature of this object is that the "num_sectors_per_side" parameter will be overridden to enable stitching to another square mesh (provided via "meshes_to_adapt_to" to this object). This object therefore creates square meshes that can be directly stitched with square meshes generated by PolygonConcentricCircleMeshGenerator and PatternedCartesianMeshGenerator. This object only works for squares instead of general polygons.
More Information
In order to adapt the external boundary to match input meshes (typically generated by PatternedCartesianMeshGenerator), two extra input parameters must be provided:
"sides_to_adapt": a vector parameter that can include up to four elements which lists the reference square side numbers to adaptively mesh. These entries must be non-repeating integers from 0 to 3 (see Figure 1). The square sides are indexed counterclockwise starting from the top side.
"meshes_to_adapt_to": a vector parameter that includes the same number of elements as "sides_to_adapt". These elements are input square meshes whose boundary nodes will be queried and used to adaptively mesh a side of the square mesh being created. The input square meshes are generated by
PatternedCartesianMeshGeneratororPolygonConcentricCircleMeshGenerator. Multiple meshes may be input, each one corresponding to the side index value specified in "sides_to_adapt". The same input mesh may be repeated multiple times.
Figure 1: A schematic drawing showing the square side indices in CartesianConcentricCircleAdaptiveBoundaryMeshGenerator object.
The "square_size" provided here must be consistent with the "square_size" values of all the "meshes_to_adapt_to" generators.
The mesh generator can generate meshes with either linear or quadratic elements, which is controlled by the "tri_element_type" and "quad_element_type" parameters. The "meshes_to_adapt_to" must have the consistent element types for compatibility.
One major application of this object is to generate meshes for control drums. In that case, "is_control_drum" can be set as true so that corresponding MeshMetaData can be generated for future use with control drum related objects.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
[fmg]
type = FileMeshGenerator<<<{"description": "Read a mesh from a file.", "href": "FileMeshGenerator.html"}>>>
file<<<{"description": "The filename to read."}>>> = square_in.e
[gen]
type = CartesianConcentricCircleAdaptiveBoundaryMeshGenerator<<<{"description": "This CartesianConcentricCircleAdaptiveBoundaryMeshGenerator object is designed to generate square meshes with adaptive boundary to facilitate stitching.", "href": "CartesianConcentricCircleAdaptiveBoundaryMeshGenerator.html"}>>>
num_sectors_per_side<<<{"description": "Number of azimuthal sectors per polygon side (rotating counterclockwise from top right face)."}>>> = '4 4 4 4'
background_intervals<<<{"description": "Number of radial meshing intervals in background region (area between rings and ducts) excluding the background's boundary layers."}>>> = 2
square_size<<<{"description": "Size (side length) of the square mesh to be generated."}>>> = 10.0
sides_to_adapt<<<{"description": "List of the square reference side indices that correspond to the sides that need adaptive meshing. The meshes to adapt these sides to are provided in 'inputs'."}>>> = 0
meshes_to_adapt_to<<<{"description": "The name list of the input meshes to adapt to."}>>> = 'fmg'
[](contrib/moose/modules/reactor/test/tests/meshgenerators/cartesian_concentric_circle_adaptive_boundary_generator/square_2d.i)Here, a simple square mesh stored in an Exodus file is used as the input of CartesianConcentricCircleAdaptiveBoundaryMeshGenerator. Only Side 0 of the generated mesh is set to adapt the input mesh (i.e., Side 2 of the input mesh), as shown in Figure 2. Note that only Side 0 of the generated mesh matches the input mesh (Side 2).
Figure 2: A schematic drawing showing the input and generated meshes of the example case.
Input Parameters
- background_inner_boundary_layer_bias1Growth factor used for mesh biasing of the background inner boundary layer.
Default:1
C++ Type:double
Range:background_inner_boundary_layer_bias>0
Controllable:No
Description:Growth factor used for mesh biasing of the background inner boundary layer.
- background_inner_boundary_layer_intervals1Number of radial intervals of the background inner boundary layer
Default:1
C++ Type:unsigned int
Range:background_inner_boundary_layer_intervals>0
Controllable:No
Description:Number of radial intervals of the background inner boundary layer
- background_inner_boundary_layer_width0Width of background region that is assigned to be the inner boundary layer.
Default:0
C++ Type:double
Range:background_inner_boundary_layer_width>=0
Controllable:No
Description:Width of background region that is assigned to be the inner boundary layer.
- background_outer_boundary_layer_bias1Growth factor used for mesh biasing of the background outer boundary layer.
Default:1
C++ Type:double
Range:background_outer_boundary_layer_bias>0
Controllable:No
Description:Growth factor used for mesh biasing of the background outer boundary layer.
- background_outer_boundary_layer_intervals1Number of radial intervals of the background outer boundary layer
Default:1
Range:background_outer_boundary_layer_intervals>0
Controllable:No
Description:Number of radial intervals of the background outer boundary layer
- background_outer_boundary_layer_width0Width of background region that is assigned to be the outer boundary layer.
Default:0
C++ Type:double
Range:background_outer_boundary_layer_width>=0
Controllable:No
Description:Width of background region that is assigned to be the outer boundary layer.
- background_radial_bias1Value used to create biasing in radial meshing for background region.
Default:1
C++ Type:double
Range:background_radial_bias>0
Controllable:No
Description:Value used to create biasing in radial meshing for background region.
- duct_inner_boundary_layer_biasesGrowth factors used for mesh biasing of the duct inner boundary layers.
C++ Type:std::vector<double>
Range:duct_inner_boundary_layer_biases>0
Controllable:No
Description:Growth factors used for mesh biasing of the duct inner boundary layers.
- duct_inner_boundary_layer_intervalsNumber of radial intervals of the duct inner boundary layers
C++ Type:std::vector<unsigned int>
Controllable:No
Description:Number of radial intervals of the duct inner boundary layers
- duct_inner_boundary_layer_widthsWidths of duct regions that are assigned to be the inner boundary layers.
Range:duct_inner_boundary_layer_widths>=0
Controllable:No
Description:Widths of duct regions that are assigned to be the inner boundary layers.
- duct_outer_boundary_layer_biasesGrowth factors used for mesh biasing of the duct outer boundary layers.
Range:duct_outer_boundary_layer_biases>0
Controllable:No
Description:Growth factors used for mesh biasing of the duct outer boundary layers.
- duct_outer_boundary_layer_intervalsNumber of radial intervals of the duct outer boundary layers
Controllable:No
Description:Number of radial intervals of the duct outer boundary layers
- duct_outer_boundary_layer_widthsWidths of duct regions that are assigned to be the outer boundary layers.
Range:duct_outer_boundary_layer_widths>=0
Controllable:No
Description:Widths of duct regions that are assigned to be the outer boundary layers.
- duct_radial_biasesValues used to create biasing in radial meshing for duct regions.
Range:duct_radial_biases>0
Controllable:No
Description:Values used to create biasing in radial meshing for duct regions.
- duct_sizesDistance(s) from polygon center to duct(s) inner boundaries.
Controllable:No
Description:Distance(s) from polygon center to duct(s) inner boundaries.
- duct_sizes_styleradiusStyle in which polygon center to duct inner boundary distance is given (apothem = center to face, radius = center to vertex). Options: apothem radius
Default:radius
C++ Type:MooseEnum
Controllable:No
Description:Style in which polygon center to duct inner boundary distance is given (apothem = center to face, radius = center to vertex). Options: apothem radius
- meshes_to_adapt_toThe name list of the input meshes to adapt to.
C++ Type:std::vector<MeshGeneratorName>
Controllable:No
Description:The name list of the input meshes to adapt to.
- preserve_volumesTrueVolume of concentric circles can be preserved using this function.
Default:True
C++ Type:bool
Controllable:No
Description:Volume of concentric circles can be preserved using this function.
- quad_element_typeQUAD4Type of the quadrilateral elements to be generated.
Default:QUAD4
C++ Type:MooseEnum
Controllable:No
Description:Type of the quadrilateral elements to be generated.
- ring_radiiRadii of major concentric circles (rings).
Range:ring_radii>0
Controllable:No
Description:Radii of major concentric circles (rings).
- sides_to_adaptList of the square reference side indices that correspond to the sides that need adaptive meshing. The meshes to adapt these sides to are provided in 'inputs'.
Controllable:No
Description:List of the square reference side indices that correspond to the sides that need adaptive meshing. The meshes to adapt these sides to are provided in 'inputs'.
- tri_element_typeTRI3Type of the triangular elements to be generated.
Default:TRI3
C++ Type:MooseEnum
Controllable:No
Description:Type of the triangular elements to be generated.
Optional Parameters
- background_block_idsOptional customized block id for the background block.
C++ Type:std::vector<unsigned short>
Controllable:No
Description:Optional customized block id for the background block.
- background_block_namesOptional customized block names for the background block.
C++ Type:std::vector<SubdomainName>
Controllable:No
Description:Optional customized block names for the background block.
- block_id_shift0Integer used to shift block IDs.
Default:0
C++ Type:unsigned short
Controllable:No
Description:Integer used to shift block IDs.
- create_inward_interface_boundariesFalseWhether the inward interface boundaries are created.
Default:False
C++ Type:bool
Controllable:No
Description:Whether the inward interface boundaries are created.
- create_outward_interface_boundariesTrueWhether the outward interface boundaries are created.
Default:True
C++ Type:bool
Controllable:No
Description:Whether the outward interface boundaries are created.
- duct_block_idsOptional customized block ids for each duct geometry block.
Controllable:No
Description:Optional customized block ids for each duct geometry block.
- duct_block_namesOptional customized block names for each duct geometry block.
Controllable:No
Description:Optional customized block names for each duct geometry block.
- external_boundary_idOptional customized external boundary id.
C++ Type:short
Range:external_boundary_id>0
Controllable:No
Description:Optional customized external boundary id.
- external_boundary_nameOptional customized external boundary name.
C++ Type:BoundaryName
Controllable:No
Description:Optional customized external boundary name.
- generate_side_specific_boundariesFalsewhether the side-specific external boundaries are generated or not
Default:False
C++ Type:bool
Controllable:No
Description:whether the side-specific external boundaries are generated or not
- interface_boundary_id_shift0Integer used to shift interface boundary IDs.
Default:0
C++ Type:short
Controllable:No
Description:Integer used to shift interface boundary IDs.
- inward_interface_boundary_namesOptional customized boundary names for the internal inward interfaces between block.
C++ Type:std::vector<std::string>
Controllable:No
Description:Optional customized boundary names for the internal inward interfaces between block.
- outward_interface_boundary_namesOptional customized boundary names for the internal outward interfaces between block.
Controllable:No
Description:Optional customized boundary names for the internal outward interfaces between block.
- ring_block_idsOptional customized block ids for each ring geometry block.
Controllable:No
Description:Optional customized block ids for each ring geometry block.
- ring_block_namesOptional customized block names for each ring geometry block.
Controllable:No
Description:Optional customized block names for each ring geometry block.
Customized Subdomain/Boundary Parameters
- background_intervals1Number of radial meshing intervals in background region (area between rings and ducts) excluding the background's boundary layers.
Default:1
Range:background_intervals>0
Controllable:No
Description:Number of radial meshing intervals in background region (area between rings and ducts) excluding the background's boundary layers.
- duct_intervalsNumber of meshing intervals in each enclosing duct excluding duct boundary layers.
Range:duct_intervals>0
Controllable:No
Description:Number of meshing intervals in each enclosing duct excluding duct boundary layers.
- num_sectors_per_sideNumber of azimuthal sectors per polygon side (rotating counterclockwise from top right face).
Range:num_sectors_per_side>0
Controllable:No
Description:Number of azimuthal sectors per polygon side (rotating counterclockwise from top right face).
- ring_intervalsNumber of radial mesh intervals within each major concentric circle excluding their boundary layers.
Range:ring_intervals>0
Controllable:No
Description:Number of radial mesh intervals within each major concentric circle excluding their boundary layers.
General Mesh Density Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- inner_ring_desired_areaDesired area as a function of x,y; omit to use the default constant area (square of the smallest side length on the ring circle)
Controllable:No
Description:Desired area as a function of x,y; omit to use the default constant area (square of the smallest side length on the ring circle)
- replace_inner_ring_with_delaunay_meshFalseTrue to replace the inner ring mesh with a Delaunay unstructured mesh
Default:False
C++ Type:bool
Controllable:No
Description:True to replace the inner ring mesh with a Delaunay unstructured mesh
Inner Ring Parameters
- is_control_drumFalseWhether this mesh is for a control drum. The value can be set as 'false' if the user wants to use this object for other components.
Default:False
C++ Type:bool
Controllable:No
Description:Whether this mesh is for a control drum. The value can be set as 'false' if the user wants to use this object for other components.
Control Drum Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
- ring_id_assign_typeblock_wiseType of ring ID assignment: block_wise or ring_wise
Default:block_wise
C++ Type:MooseEnum
Controllable:No
Description:Type of ring ID assignment: block_wise or ring_wise
- ring_id_nameName of integer (reporting) ID for ring regions to use the reporting ID for annular regions of ring geometry block.
Controllable:No
Description:Name of integer (reporting) ID for ring regions to use the reporting ID for annular regions of ring geometry block.
- sector_id_nameName of integer (reporting) ID for sector regions to use the reporting ID for azimuthal sector regions of ring geometry block.
Controllable:No
Description:Name of integer (reporting) ID for sector regions to use the reporting ID for azimuthal sector regions of ring geometry block.
Ring/Sector Ids Parameters
- ring_inner_boundary_layer_biasesGrowth factors used for mesh biasing of the rings' inner boundary layers.
Range:ring_inner_boundary_layer_biases>0
Controllable:No
Description:Growth factors used for mesh biasing of the rings' inner boundary layers.
- ring_inner_boundary_layer_intervalsNumber of radial intervals of the rings' inner boundary layers
Controllable:No
Description:Number of radial intervals of the rings' inner boundary layers
- ring_inner_boundary_layer_widthsWidths of each ring regions that are assigned to be each ring's inner boundary layers.
Range:ring_inner_boundary_layer_widths>=0
Controllable:No
Description:Widths of each ring regions that are assigned to be each ring's inner boundary layers.
- ring_outer_boundary_layer_biasesGrowth factors used for mesh biasing of the rings' outer boundary layers.
Range:ring_outer_boundary_layer_biases>0
Controllable:No
Description:Growth factors used for mesh biasing of the rings' outer boundary layers.
- ring_outer_boundary_layer_intervalsNumber of radial intervals of the rings' outer boundary layers
Controllable:No
Description:Number of radial intervals of the rings' outer boundary layers
- ring_outer_boundary_layer_widthsWidths of each ring regions that are assigned to be each ring's outer boundary layers.
Range:ring_outer_boundary_layer_widths>=0
Controllable:No
Description:Widths of each ring regions that are assigned to be each ring's outer boundary layers.
- ring_radial_biasesValues used to create biasing in radial meshing for ring regions.
Range:ring_radial_biases>0
Controllable:No
Description:Values used to create biasing in radial meshing for ring regions.
