PolygonConcentricCircleMeshGenerator
This PolygonConcentricCircleMeshGenerator object is designed to mesh a polygon geometry with optional rings centered inside.
Overview
Typical meshes generated by this `PolygonConcentricCircleMeshGenerator` object: the left mesh consists of linear elements while the right mesh consists of quadratic elements.
Figure 1: Typical meshes generated by this PolygonConcentricCircleMeshGenerator object: the left mesh consists of linear elements while the right mesh consists of quadratic elements.
The PolygonConcentricCircleMeshGenerator object generates a 2D mesh for concentric circles with a regular polygon enclosure with or without external ducts. Typical meshes generated by this object are shown in Figure 1. By default, the generated mesh consists of linear elements. If quadratic elements are preferred, users can set "tri_element_type" as TRI6 or TRI7, and "quad_element_type" as QUAD8 or QUAD9. Polygons with 3 or more sides (e.g. triangle, square, pentagon, hexagon,...) can be meshed using this object. The central concentric circular regions (termed rings) as well as the peripheral polygonal regions (termed ducts) are optional (see Figure 2). The region excluding any rings and ducts is termed the background region.
Geometry Information
The most fundamental geometry parameters that are needed by this object is:
A schematic drawing showing the different regions that can be generated by this `PolygonConcentricCircleMeshGenerator` object.
Figure 2: A schematic drawing showing the different regions that can be generated by this PolygonConcentricCircleMeshGenerator object.
If concentric circle regions are needed, "ring_radii" must be provided to define the outer radius of each ring. If duct regions are needed, "duct_sizes" must be provided to define the inner boundary of each duct. Similar to "polygon_size", "duct_sizes" can either be apothems or radii of the corresponding ducts, decided by "duct_sizes_style".
Mesh Information
The parameters that are needed for meshing can be categorized into azimuthal and radial information, which determine the mesh density.
The azimuthal mesh discretization is controlled by "num_sectors_per_side", which is a vector that has the same length as "num_sides". Each element of "num_sectors_per_side" must be an even integer, which is the number of azimuthal intervals of the corresponding side. The sides are indexed counterclockwise with the upper-right polygon side being the first side as shown in Figure 2.
The radial mesh discretization is controlled by separate parameters for rings, background and ducts regions, which are "ring_intervals", "background_intervals", and "duct_intervals", respectively.
In addition, the radial meshing density of each rings, background and ducts region can be biased by setting corresponding parameters, which are "ring_radial_biases", "background_radial_bias", and "duct_radial_biases", respectively. The bias value should be a positive Real type parameter, which is the radial dimension ratio between two radially-neighboring elements (outer to inner).
Boundary Layers
Aside from the general mesh radial biasing options described above, users can also define boundary layers on each ring, background, and duct regions. For each region, both inner and outer boundary layers are supported (in this case, inner boundary layer refers to a boundary layer on the volume closer to the center of the polygon, and outer boundary layer refers to a boundary layer on the volume further from the center of the polygon; these two volumes are separated by the boundary itself). Each boundary layer requires three key input parameters:
If there are multiple ring/duct regions in the generated mesh, the boundary layer related parameters of all these regions must be provided together as vectors.
MeshMeshData Generation
When "num_sides" is set as 6, the hexagonal meshes produced by PolygonConcentricCircleMeshGenerator can be used by PatternedHexMeshGenerator to create patterned meshes. This functionality relies on a series of MeshMetaData generated by PolygonConcentricCircleMeshGenerator, including:
  • pitch_meta, type Real: Provides the side-to-side distance of the hexagon generated.
  • pattern_pitch_meta, type Real: Similar to pitch_meta. This is only used when the mesh produced here is stitched with assembly hexagon meshes generated by PatternedHexMeshGenerator.
  • background_intervals_meta, type unsigned int: Makes the value of the input parameter "background_intervals" available to other mesh generators.
  • node_id_background_meta, type dof_id_type: Records the maximum node id of the background nodes to provide a reference for node modifications.
  • max_radius_meta, type Real: Provides the maximum radius of the ring regions so that PatternedHexMeshGenerator does not compromise the circular geometry.
  • num_sectors_per_side_meta, type std::vector<unsigned int>: Makes the value of the input parameter "num_sectors_per_side" available to other mesh generators.
  • azimuthal_angle_meta, type std::vector<Real>: Contains the sorted azimuthal angles of all the nodes on the external boundary.
Reporting ID Assignment
PolygonConcentricCircleMeshGenerator can assign the reporting IDs for annular rings and sectors, which allows users to manipulate sub-pin level details information such as such as the depletion zone setup. The option for ring and sector reporting IDs can be turned on by defining the input parameters "ring_id_name" and "sector_id_name", respectively.
For the ring reporting IDs, each annular blocks defined by "ring_radii" has its own ID values by default. The default may be overridden by unique ID values by setting "ring_id_assign_type" as ring_wise, if both "ring_radii" and "ring_intervals" are specified.
Other Information
By default, the mesh generated by this object contains a mixture of QUAD4 and TRI3 elements. To be specific, the central region of the mesh consists of triangular elements, whereas the rest of the mesh consists of quadrilateral elements. The users also have an option to generate a purely QUAD4 mesh by setting quad_center_elements as true (see Figure 3). In that case, the factor shown in Figure 3 can also be customized using "center_quad_factor".
A schematic drawing showing the different meshing algorithms when [!param](/Mesh/PolygonConcentricCircleMeshGenerator/quad_center_elements) is set as `false` and `true`.
Figure 3: A schematic drawing showing the different meshing algorithms when "quad_center_elements" is set as false and true.
Users can also set "replace_inner_ring_with_delaunay_mesh" to true to replace the inner ring with an unstructured Delaunay triangular mesh as illustrated in Figure 4.
Example meshes when [!param](/Mesh/PolygonConcentricCircleMeshGenerator/replace_inner_ring_with_delaunay_mesh) is set as `false` and `true`.
Figure 4: Example meshes when "replace_inner_ring_with_delaunay_mesh" is set as false and true.
The left figure is generated with two intervals for the inner ring and the right figure is generated with "replace_inner_ring_with_delaunay_mesh" equal to true. This feature is useful in a situation when the number of total sectors is large making the center point connected with too many elements. When this parameter is true, "quad_center_elements" cannot be set otherwise an error will be thrown. The first element of "ring_intervals" is ignored and the element areas are controlled by "inner_ring_desired_area" function. The function can be a constant value. The default empty string means that the code will pick a default desired area which is the square of the smallest side length on the ring circle. The unstructured Delaunay mesh of the inner ring will have the triangle element type specified in "tri_element_type". It will also have the subdomain ID/name of the original subdomain ID/name of the triangular elements of the inner ring, the first value in "ring_block_ids" and "ring_block_names". If the first element of "ring_intervals" is greater than one, the second elements of "ring_block_ids" and "ring_block_names" for the inner ring are ignored. When "ring_id_name" is specified, the element ring IDs will be all equal to one. When "sector_id_name" is specified, the element sector IDs will be all equal to zero. If the new feature is used, the first elements of "ring_inner_boundary_layer_biases", "ring_inner_boundary_layer_intervals", "ring_inner_boundary_layer_widths", "ring_inner_boundary_layer_biases", "ring_inner_boundary_layer_intervals", "ring_inner_boundary_layer_widths" and "ring_radial_biases" are all ignored.
When rings regions are present, the radii of these rings can be auto-adjusted to preserve the meshed annular area (volume) to the true area (volume) by setting "preserve_volumes" as true. The volume preservation feature is compatible with quadratic elements.
By default, the azimuthal angles used to discretize the mesh are uniformly spaced in _angle_ on each sector of the polygon. However, uniform spacing of angles leads to non-uniform mesh intervals on the polygon external sides (unless exactly 2 sectors per side are used). However, as a uniformly spaced mesh on the polygon external boundary may facilitate mesh stitching, the user may force a uniform mesh on the polygon external boundary by setting "uniform_mesh_on_sides" as true.
The default block id numbering starts with 0 at the center region and increments by 1 for each mesh region radially outward. The user may instead set specific block id and name values to rings, background, and duct regions through the use of "ring_block_ids", "background_block_ids", "duct_block_ids", "ring_block_names", "background_block_names", and "duct_block_names".
The user should be aware that in two cases, the central geometric region is defined as two blocks instead of one: - When rings are not present, and "background_intervals" > 1 or a boundary layer is defined in this region - When rings are present, and the first entry of "ring_intervals" > 1 or a boundary layer is defined in this region
In both of these cases, the central geometric region will contain both blocks 0 and 1 by default. Any additional usage of block ids or name arrays will require an extra entry for the first geometric region. This extra block definition is needed to accommodate flexibility in defining the central region as either quadrilateral or triangular elements while still stitching properly to the neighboring region. Note that if "quad_center_elements" is set as true, the central geometric region is allowed to have a uniform block id/name. This can be achieved by providing a pair of duplicated block ids/names in the corresponding customized block ids/names input parameter. The user can also provide a single customized block id/name for the central geometric region in this case and the system will duplicate the input for the user.
The external boundary has a default boundary id of 10000. The user may instead set specific boundary id and/or name values through the use of external_boundary_id and external_boundary_name. Additionally, for each half side of the polygon, an independent boundary id can be optionally generated for side-specific applications by setting "generate_side_specific_boundaries" as true.
Interface Boundaries
The user can also decide whether the interface boundaries are generated or not.
There are two types of interface boundaries, "inward interface boundaries" and "outward interface boundaries". The "inward" and "outward" here refer to the direction of the boundary's normal vector. As a sideset must be defined on the sides of elements, which belong to one or multiple subdomains, an interface boundary can be defined either on the subdomain immediately inside the interface (i.e., with an "outward" normal vector) or on the subdomain immediately outside the interface (i.e., with an "inward" normal vector).
The user can set "create_inward_interface_boundaries" and "create_outward_interface_boundaries" to control which interface boundaries will be created. If generated, the outward interface boundaries will be assigned ids using sequential odd numbers (i.e., 1, 3, 5, 7, ...) from center to periphery, while the inward interface boundaries will be assigned ids using sequential even numbers (i.e., 2, 4, 6, 8, ...) similarly. These ids can be shifted by a user-provided parameter "interface_boundary_id_shift". The interface boundary names can also be specified through "inward_interface_boundary_names" and "outward_interface_boundary_names".
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [hex_1]
    type = PolygonConcentricCircleMeshGenerator<<<{"description": "This PolygonConcentricCircleMeshGenerator object is designed to mesh a polygon geometry with optional rings centered inside.", "href": "PolygonConcentricCircleMeshGenerator.html"}>>>
    num_sides<<<{"description": "Number of sides of the polygon."}>>> = 6
    num_sectors_per_side<<<{"description": "Number of azimuthal sectors per polygon side (rotating counterclockwise from top right face)."}>>> = '4 4 4 4 4 4'
    background_intervals<<<{"description": "Number of radial meshing intervals in background region (area between rings and ducts) excluding the background's boundary layers."}>>> = 2
    ring_radii<<<{"description": "Radii of major concentric circles (rings)."}>>> = 4.0
    ring_intervals<<<{"description": "Number of radial mesh intervals within each major concentric circle excluding their boundary layers."}>>> = 2
    ring_block_ids<<<{"description": "Optional customized block ids for each ring geometry block."}>>> = '10 15'
    ring_block_names<<<{"description": "Optional customized block names for each ring geometry block."}>>> = 'center_tri center'
    background_block_ids<<<{"description": "Optional customized block id for the background block."}>>> = 20
    background_block_names<<<{"description": "Optional customized block names for the background block."}>>> = background
    polygon_size<<<{"description": "Size of the polygon to be generated (given as either apothem or radius depending on polygon_size_style)."}>>> = 5.0
    preserve_volumes<<<{"description": "Volume of concentric circles can be preserved using this function."}>>> = on
(contrib/moose/modules/reactor/test/tests/meshgenerators/patterned_hex_mesh_generator/patterned_pattern.i)
Input Parameters
  • polygon_sizeSize of the polygon to be generated (given as either apothem or radius depending on polygon_size_style).
    C++ Type:double
    Unit:(no unit assumed)
    Range:polygon_size>0.0
    Controllable:No
    Description:Size of the polygon to be generated (given as either apothem or radius depending on polygon_size_style).
Required Parameters
  • background_inner_boundary_layer_bias1Growth factor used for mesh biasing of the background inner boundary layer.
    Default:1
    C++ Type:double
    Range:background_inner_boundary_layer_bias>0
    Controllable:No
    Description:Growth factor used for mesh biasing of the background inner boundary layer.
  • background_inner_boundary_layer_intervals1Number of radial intervals of the background inner boundary layer
    Default:1
    C++ Type:unsigned int
    Range:background_inner_boundary_layer_intervals>0
    Controllable:No
    Description:Number of radial intervals of the background inner boundary layer
  • background_inner_boundary_layer_width0Width of background region that is assigned to be the inner boundary layer.
    Default:0
    C++ Type:double
    Range:background_inner_boundary_layer_width>=0
    Controllable:No
    Description:Width of background region that is assigned to be the inner boundary layer.
  • background_outer_boundary_layer_bias1Growth factor used for mesh biasing of the background outer boundary layer.
    Default:1
    C++ Type:double
    Range:background_outer_boundary_layer_bias>0
    Controllable:No
    Description:Growth factor used for mesh biasing of the background outer boundary layer.
  • background_outer_boundary_layer_intervals1Number of radial intervals of the background outer boundary layer
    Default:1
    Range:background_outer_boundary_layer_intervals>0
    Controllable:No
    Description:Number of radial intervals of the background outer boundary layer
  • background_outer_boundary_layer_width0Width of background region that is assigned to be the outer boundary layer.
    Default:0
    C++ Type:double
    Range:background_outer_boundary_layer_width>=0
    Controllable:No
    Description:Width of background region that is assigned to be the outer boundary layer.
  • background_radial_bias1Value used to create biasing in radial meshing for background region.
    Default:1
    C++ Type:double
    Range:background_radial_bias>0
    Controllable:No
    Description:Value used to create biasing in radial meshing for background region.
  • duct_inner_boundary_layer_biasesGrowth factors used for mesh biasing of the duct inner boundary layers.
    C++ Type:std::vector<double>
    Range:duct_inner_boundary_layer_biases>0
    Controllable:No
    Description:Growth factors used for mesh biasing of the duct inner boundary layers.
  • duct_inner_boundary_layer_intervalsNumber of radial intervals of the duct inner boundary layers
    C++ Type:std::vector<unsigned int>
    Controllable:No
    Description:Number of radial intervals of the duct inner boundary layers
  • duct_inner_boundary_layer_widthsWidths of duct regions that are assigned to be the inner boundary layers.
    Range:duct_inner_boundary_layer_widths>=0
    Controllable:No
    Description:Widths of duct regions that are assigned to be the inner boundary layers.
  • duct_outer_boundary_layer_biasesGrowth factors used for mesh biasing of the duct outer boundary layers.
    Range:duct_outer_boundary_layer_biases>0
    Controllable:No
    Description:Growth factors used for mesh biasing of the duct outer boundary layers.
  • duct_outer_boundary_layer_intervalsNumber of radial intervals of the duct outer boundary layers
    Controllable:No
    Description:Number of radial intervals of the duct outer boundary layers
  • duct_outer_boundary_layer_widthsWidths of duct regions that are assigned to be the outer boundary layers.
    Range:duct_outer_boundary_layer_widths>=0
    Controllable:No
    Description:Widths of duct regions that are assigned to be the outer boundary layers.
  • duct_radial_biasesValues used to create biasing in radial meshing for duct regions.
    Range:duct_radial_biases>0
    Controllable:No
    Description:Values used to create biasing in radial meshing for duct regions.
  • duct_sizesDistance(s) from polygon center to duct(s) inner boundaries.
    Controllable:No
    Description:Distance(s) from polygon center to duct(s) inner boundaries.
  • duct_sizes_styleradiusStyle in which polygon center to duct inner boundary distance is given (apothem = center to face, radius = center to vertex). Options: apothem radius
    Default:radius
    C++ Type:MooseEnum
    Options:apothem, radius
    Controllable:No
    Description:Style in which polygon center to duct inner boundary distance is given (apothem = center to face, radius = center to vertex). Options: apothem radius
  • flat_side_upFalseWhether to rotate the generated polygon mesh to ensure that one flat side faces up.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether to rotate the generated polygon mesh to ensure that one flat side faces up.
  • num_sides6Number of sides of the polygon.
    Default:6
    Range:num_sides>=3
    Controllable:No
    Description:Number of sides of the polygon.
  • polygon_size_styleapothemStyle in which polygon size is given (default: apothem).
    Default:apothem
    C++ Type:MooseEnum
    Controllable:No
    Description:Style in which polygon size is given (default: apothem).
  • preserve_volumesTrueVolume of concentric circles can be preserved using this function.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Volume of concentric circles can be preserved using this function.
  • quad_element_typeQUAD4Type of the quadrilateral elements to be generated.
    Default:QUAD4
    C++ Type:MooseEnum
    Options:QUAD4, QUAD8, QUAD9
    Controllable:No
    Description:Type of the quadrilateral elements to be generated.
  • ring_radiiRadii of major concentric circles (rings).
    Range:ring_radii>0
    Controllable:No
    Description:Radii of major concentric circles (rings).
  • smoothing_max_it0Number of Laplacian smoothing iterations. This number is disregarded when duct_sizes is present.
    Default:0
    Controllable:No
    Description:Number of Laplacian smoothing iterations. This number is disregarded when duct_sizes is present.
  • tri_element_typeTRI3Type of the triangular elements to be generated.
    Default:TRI3
    C++ Type:MooseEnum
    Options:TRI3, TRI6, TRI7
    Controllable:No
    Description:Type of the triangular elements to be generated.
Optional Parameters
  • background_block_idsOptional customized block id for the background block.
    C++ Type:std::vector<unsigned short>
    Controllable:No
    Description:Optional customized block id for the background block.
  • background_block_namesOptional customized block names for the background block.
    C++ Type:std::vector<SubdomainName>
    Controllable:No
    Description:Optional customized block names for the background block.
  • block_id_shift0Integer used to shift block IDs.
    Default:0
    C++ Type:unsigned short
    Controllable:No
    Description:Integer used to shift block IDs.
  • create_inward_interface_boundariesFalseWhether the inward interface boundaries are created.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether the inward interface boundaries are created.
  • create_outward_interface_boundariesTrueWhether the outward interface boundaries are created.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Whether the outward interface boundaries are created.
  • duct_block_idsOptional customized block ids for each duct geometry block.
    Controllable:No
    Description:Optional customized block ids for each duct geometry block.
  • duct_block_namesOptional customized block names for each duct geometry block.
    Controllable:No
    Description:Optional customized block names for each duct geometry block.
  • external_boundary_idOptional customized external boundary id.
    C++ Type:short
    Range:external_boundary_id>0
    Controllable:No
    Description:Optional customized external boundary id.
  • external_boundary_nameOptional customized external boundary name.
    C++ Type:BoundaryName
    Controllable:No
    Description:Optional customized external boundary name.
  • generate_side_specific_boundariesFalsewhether the side-specific external boundaries are generated or not
    Default:False
    C++ Type:bool
    Controllable:No
    Description:whether the side-specific external boundaries are generated or not
  • interface_boundary_id_shift0Integer used to shift interface boundary IDs.
    Default:0
    C++ Type:short
    Controllable:No
    Description:Integer used to shift interface boundary IDs.
  • inward_interface_boundary_namesOptional customized boundary names for the internal inward interfaces between block.
    C++ Type:std::vector<std::string>
    Controllable:No
    Description:Optional customized boundary names for the internal inward interfaces between block.
  • outward_interface_boundary_namesOptional customized boundary names for the internal outward interfaces between block.
    Controllable:No
    Description:Optional customized boundary names for the internal outward interfaces between block.
  • ring_block_idsOptional customized block ids for each ring geometry block.
    Controllable:No
    Description:Optional customized block ids for each ring geometry block.
  • ring_block_namesOptional customized block names for each ring geometry block.
    Controllable:No
    Description:Optional customized block names for each ring geometry block.
Customized Subdomain/Boundary Parameters
  • background_intervals1Number of radial meshing intervals in background region (area between rings and ducts) excluding the background's boundary layers.
    Default:1
    Range:background_intervals>0
    Controllable:No
    Description:Number of radial meshing intervals in background region (area between rings and ducts) excluding the background's boundary layers.
  • duct_intervalsNumber of meshing intervals in each enclosing duct excluding duct boundary layers.
    Range:duct_intervals>0
    Controllable:No
    Description:Number of meshing intervals in each enclosing duct excluding duct boundary layers.
  • num_sectors_per_sideNumber of azimuthal sectors per polygon side (rotating counterclockwise from top right face).
    Range:num_sectors_per_side>0
    Controllable:No
    Description:Number of azimuthal sectors per polygon side (rotating counterclockwise from top right face).
  • ring_intervalsNumber of radial mesh intervals within each major concentric circle excluding their boundary layers.
    Range:ring_intervals>0
    Controllable:No
    Description:Number of radial mesh intervals within each major concentric circle excluding their boundary layers.
  • uniform_mesh_on_sidesFalseWhether the side elements are reorganized to have a uniform size.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether the side elements are reorganized to have a uniform size.
General Mesh Density Parameters
  • center_quad_factorA fractional radius factor used to determine the radial positions of transition nodes in the center region meshed by quad elements.
    C++ Type:double
    Range:center_quad_factor>0¢er_quad_factor<1
    Controllable:No
    Description:A fractional radius factor used to determine the radial positions of transition nodes in the center region meshed by quad elements.
  • inner_ring_desired_areaDesired area as a function of x,y; omit to use the default constant area (square of the smallest side length on the ring circle)
    C++ Type:std::string
    Controllable:No
    Description:Desired area as a function of x,y; omit to use the default constant area (square of the smallest side length on the ring circle)
  • quad_center_elementsFalseWhether the center elements are quad or triangular.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether the center elements are quad or triangular.
  • replace_inner_ring_with_delaunay_meshFalseTrue to replace the inner ring mesh with a Delaunay unstructured mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:True to replace the inner ring mesh with a Delaunay unstructured mesh
Inner Ring Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
  • ring_id_assign_typeblock_wiseType of ring ID assignment: block_wise or ring_wise
    Default:block_wise
    C++ Type:MooseEnum
    Options:block_wise, ring_wise
    Controllable:No
    Description:Type of ring ID assignment: block_wise or ring_wise
  • ring_id_nameName of integer (reporting) ID for ring regions to use the reporting ID for annular regions of ring geometry block.
    Controllable:No
    Description:Name of integer (reporting) ID for ring regions to use the reporting ID for annular regions of ring geometry block.
  • sector_id_nameName of integer (reporting) ID for sector regions to use the reporting ID for azimuthal sector regions of ring geometry block.
    Controllable:No
    Description:Name of integer (reporting) ID for sector regions to use the reporting ID for azimuthal sector regions of ring geometry block.
Ring/Sector Ids Parameters
  • ring_inner_boundary_layer_biasesGrowth factors used for mesh biasing of the rings' inner boundary layers.
    Range:ring_inner_boundary_layer_biases>0
    Controllable:No
    Description:Growth factors used for mesh biasing of the rings' inner boundary layers.
  • ring_inner_boundary_layer_intervalsNumber of radial intervals of the rings' inner boundary layers
    Controllable:No
    Description:Number of radial intervals of the rings' inner boundary layers
  • ring_inner_boundary_layer_widthsWidths of each ring regions that are assigned to be each ring's inner boundary layers.
    Range:ring_inner_boundary_layer_widths>=0
    Controllable:No
    Description:Widths of each ring regions that are assigned to be each ring's inner boundary layers.
  • ring_outer_boundary_layer_biasesGrowth factors used for mesh biasing of the rings' outer boundary layers.
    Range:ring_outer_boundary_layer_biases>0
    Controllable:No
    Description:Growth factors used for mesh biasing of the rings' outer boundary layers.
  • ring_outer_boundary_layer_intervalsNumber of radial intervals of the rings' outer boundary layers
    Controllable:No
    Description:Number of radial intervals of the rings' outer boundary layers
  • ring_outer_boundary_layer_widthsWidths of each ring regions that are assigned to be each ring's outer boundary layers.
    Range:ring_outer_boundary_layer_widths>=0
    Controllable:No
    Description:Widths of each ring regions that are assigned to be each ring's outer boundary layers.
  • ring_radial_biasesValues used to create biasing in radial meshing for ring regions.
    Range:ring_radial_biases>0
    Controllable:No
    Description:Values used to create biasing in radial meshing for ring regions.
Mesh Boundary Layers And Biasing Options Parameters
