AdvancedConcentricCircleGenerator
This AdvancedConcentricCircleGenerator object is designed to mesh a concentric circular geometry.
Overview
AdvancedConcentricCircleGenerator generates concentric circular meshes that are similar to the output of PolygonConcentricCircleMeshGenerator but without background and duct regions. While all the features of PolygonConcentricCircleMeshGenerator involving the concentric circular "ring" regions are preserved, this mesh generator has some unique features because of the absence of the polygon outer regions. The mesh generator can generate meshes with either linear or quadratic elements, which is controlled by the "tri_element_type" and "quad_element_type" parameters.
Azimuthal Mesh Density
By default, the azimuthal intervals are uniform and a single parameter "num_sectors" is used to define the total number of the azimuthal intervals.
Users can alternatively provide a list of ascending azimuthal angles between 0 to 360 through "customized_azimuthal_angles", which correspond to node angular positions of the generated mesh. Any azimuthal interval widths less than 120 are supported.
Due to the extra flexibility in azimuthal mesh density, the central elements have to be triangular.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [accg]
    type = AdvancedConcentricCircleGenerator<<<{"description": "This AdvancedConcentricCircleGenerator object is designed to mesh a concentric circular geometry.", "href": "AdvancedConcentricCircleGenerator.html"}>>>
    ring_radii<<<{"description": "Radii of major concentric circles (rings)."}>>> = '1 2'
    ring_intervals<<<{"description": "Number of radial mesh intervals within each major concentric circle excluding their boundary layers."}>>> = '2 2'
    ring_block_ids<<<{"description": "Optional customized block ids for each ring geometry block."}>>> = '10 15 20'
    ring_block_names<<<{"description": "Optional customized block names for each ring geometry block."}>>> = 'inner_tri inner outer'
    external_boundary_id<<<{"description": "Optional customized external boundary id."}>>> = 100
    external_boundary_name<<<{"description": "Optional customized external boundary name."}>>> = 'ext'
(contrib/moose/modules/reactor/test/tests/meshgenerators/advanced_concentric_circle_generator/accg.i)
An example output of `AdvancedConcentricCircleGenerator` with (8) uniform azimuthal sectors.
Figure 1: An example output of AdvancedConcentricCircleGenerator with (8) uniform azimuthal sectors.
An example output of `AdvancedConcentricCircleGenerator` with (8) customized azimuthal sectors.
Figure 2: An example output of AdvancedConcentricCircleGenerator with (8) customized azimuthal sectors.
Input Parameters
  • ring_radiiRadii of major concentric circles (rings).
    C++ Type:std::vector<double>
    Unit:(no unit assumed)
    Range:ring_radii>0
    Controllable:No
    Description:Radii of major concentric circles (rings).
Required Parameters
  • preserve_volumesTrueVolume of concentric circles can be preserved using this function.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Volume of concentric circles can be preserved using this function.
  • quad_element_typeQUAD4Type of the quadrilateral elements to be generated.
    Default:QUAD4
    C++ Type:MooseEnum
    Options:QUAD4, QUAD8, QUAD9
    Controllable:No
    Description:Type of the quadrilateral elements to be generated.
  • tri_element_typeTRI3Type of the triangular elements to be generated.
    Default:TRI3
    C++ Type:MooseEnum
    Options:TRI3, TRI6, TRI7
    Controllable:No
    Description:Type of the triangular elements to be generated.
Optional Parameters
  • block_id_shift0Integer used to shift block IDs.
    Default:0
    C++ Type:unsigned short
    Controllable:No
    Description:Integer used to shift block IDs.
  • create_inward_interface_boundariesFalseWhether the inward interface boundaries are created.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether the inward interface boundaries are created.
  • create_outward_interface_boundariesTrueWhether the outward interface boundaries are created.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Whether the outward interface boundaries are created.
  • external_boundary_idOptional customized external boundary id.
    C++ Type:short
    Range:external_boundary_id>0
    Controllable:No
    Description:Optional customized external boundary id.
  • external_boundary_nameOptional customized external boundary name.
    C++ Type:BoundaryName
    Controllable:No
    Description:Optional customized external boundary name.
  • generate_side_specific_boundariesFalsewhether the side-specific external boundaries are generated or not
    Default:False
    C++ Type:bool
    Controllable:No
    Description:whether the side-specific external boundaries are generated or not
  • interface_boundary_id_shift0Integer used to shift interface boundary IDs.
    Default:0
    C++ Type:short
    Controllable:No
    Description:Integer used to shift interface boundary IDs.
  • inward_interface_boundary_namesOptional customized boundary names for the internal inward interfaces between block.
    C++ Type:std::vector<std::string>
    Controllable:No
    Description:Optional customized boundary names for the internal inward interfaces between block.
  • outward_interface_boundary_namesOptional customized boundary names for the internal outward interfaces between block.
    Controllable:No
    Description:Optional customized boundary names for the internal outward interfaces between block.
  • ring_block_idsOptional customized block ids for each ring geometry block.
    C++ Type:std::vector<unsigned short>
    Controllable:No
    Description:Optional customized block ids for each ring geometry block.
  • ring_block_namesOptional customized block names for each ring geometry block.
    C++ Type:std::vector<SubdomainName>
    Controllable:No
    Description:Optional customized block names for each ring geometry block.
Customized Subdomain/Boundary Parameters
  • customized_azimuthal_anglesList of the user-specified azimuthal angles of the nodes.
    Range:customized_azimuthal_angles>=0&customized_azimuthal_angles<360
    Controllable:No
    Description:List of the user-specified azimuthal angles of the nodes.
  • num_sectorsNumber of azimuthal sectors of the circular mesh to be generated.
    C++ Type:unsigned int
    Range:num_sectors>2
    Controllable:No
    Description:Number of azimuthal sectors of the circular mesh to be generated.
Azimuthal Mesh Density Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
  • ring_inner_boundary_layer_biasesGrowth factors used for mesh biasing of the rings' inner boundary layers.
    Range:ring_inner_boundary_layer_biases>0
    Controllable:No
    Description:Growth factors used for mesh biasing of the rings' inner boundary layers.
  • ring_inner_boundary_layer_intervalsNumber of radial intervals of the rings' inner boundary layers
    C++ Type:std::vector<unsigned int>
    Controllable:No
    Description:Number of radial intervals of the rings' inner boundary layers
  • ring_inner_boundary_layer_widthsWidths of each ring regions that are assigned to be each ring's inner boundary layers.
    Range:ring_inner_boundary_layer_widths>=0
    Controllable:No
    Description:Widths of each ring regions that are assigned to be each ring's inner boundary layers.
  • ring_outer_boundary_layer_biasesGrowth factors used for mesh biasing of the rings' outer boundary layers.
    Range:ring_outer_boundary_layer_biases>0
    Controllable:No
    Description:Growth factors used for mesh biasing of the rings' outer boundary layers.
  • ring_outer_boundary_layer_intervalsNumber of radial intervals of the rings' outer boundary layers
    Controllable:No
    Description:Number of radial intervals of the rings' outer boundary layers
  • ring_outer_boundary_layer_widthsWidths of each ring regions that are assigned to be each ring's outer boundary layers.
    Range:ring_outer_boundary_layer_widths>=0
    Controllable:No
    Description:Widths of each ring regions that are assigned to be each ring's outer boundary layers.
  • ring_radial_biasesValues used to create biasing in radial meshing for ring regions.
    Range:ring_radial_biases>0
    Controllable:No
    Description:Values used to create biasing in radial meshing for ring regions.
Mesh Boundary Layers And Biasing Options Parameters
  • ring_intervalsNumber of radial mesh intervals within each major concentric circle excluding their boundary layers.
    Range:ring_intervals>0
    Controllable:No
    Description:Number of radial mesh intervals within each major concentric circle excluding their boundary layers.
General Mesh Density Parameters
