Troubleshooting the Test Suite
This page addresses errors commonly encountered when running the regression test suite, with ./run_tests.
All the OpenMC tests Exodiff/CSVDiff
There are two general reasons why all of the OpenMC tests might fail with an Exodiff or CSVDiff (meaning that the test ran, but the code results do not match what the test suite expects to encounter for tally values):
  • You did not use the cross section set that Cardinal expects to use for the test suite. You can find this test suite here.
  • If you are on a Mac, it is known that OpenMC itself does not output identical solutions when compared to Linux operating systems. See this issue on the OpenMC github for more information. In this case, as long as the tests ran (i.e. they did not crash or abort, but did run successfully), you can proceed as normal.
Missing Python dependencies
Cardinal's test suite requires some Python dependencies that ship with MOOSE. You might encounter an error like:
Traceback (most recent call last):
  File "/Users/anovak/projects/cardinal/./run_tests", line 11, in <module>
    from TestHarness import TestHarness
ModuleNotFoundError: No module named 'TestHarness'
This means that you need to:
  • Be sure that your Python is version 3 (python --version will show you the version)
  • Add cardinal/contrib/moose/python to your PYTHONPATH to be sure Python can find TestHarness
Missing libmesh-config
If you encounter an error like
Error! Could not find 'libmesh-config' in any of the usual libmesh's locations!
This means that you need to explicitly set LIBMESH_DIR to point to where you have moose/libmesh. If you're using MOOSE's conda environment, this means setting LIBMESH_DIR to $CONDA_PREFIX/libmesh. If not using the conda environment, set to cardinal/contrib/moose/libmesh/installed. You may also need to explicitly set MOOSE_DIR to point to cardinal/contrib/moose.
Timeout NekRS tests
The first time that you run a NekRS input file, NekRS does just-in-time compilation of the OCCA kernels, which can be very slow. MOOSE's default timeout for a test is a runtime of 300 seconds. If your system does not have very many cores, a lot of the NekRS-related tests can fail the first time you run the test suite. Just try re-running again, in which case NekRS will be able to re-use the build files you created during the first pass so that the tests are much faster.
Crashing NekRS tests
NekRS is known to randomly fail to precompile tests; see for example this old issue. It is rare for these failures to happen when running a simulation using cardinal-opt directly, but for some reason they can be much more common when running a case through MOOSE's test harness via ./run_tests. You may encounter random "crash" type test failures with error messages related to "undefined symbols" or "dlopen" failures, to give a few examples. As long as you can run the test directly with cardinal-opt, these failures do not imapct the code's correctness or usability. We are diagnosing these issues longer-term.
