Getting Cross Section Data
OpenMC requires cross section data in HDF5 format. Cardinal's test suite assumes that you are using a specific data library that you can obtain by running
./scripts/download-openmc-cross-sections.sh
This script will place cross section data into a directory name cross_sections one directory "above" the Cardinal repository, so that you'd set OPENMC_CROSS_SECTIONS to something like the following (if you have the Cardinal repository located at $HOME/cardinal):
export OPENMC_CROSS_SECTIONS=$HOME/cross_sections/endfb-vii.1-hdf5/cross_sections.xml
For other libraries, please refer to the OpenMC cross section documentation.
