SCM model for the Toshiba 37-pin benchmark
Contact: Mauricio Tano, mauricio.tanoretamales.at.inl.gov
Benchmark Description
The Toshiba 37-pin benchmark is based on liquid sodium experiments conducted by the Toshiba Corporation Nuclear Engineering Laboratory in Japan (Namekawa et al., 1984). Its assembly consists of four outer rings of electrically heated pins. However, the resistances in the electrically heated pins are adapted to reproduce a chopped cosine power distribution in the axial direction. All heating pins are assumed to have the same power distribution. The cross section of the fuel assembly is presented in Figure 1. In this figure the numbering of the pins and the subchannels are described. The analyzed quantity of interest is the temperature distribution at the outlet of the assembly. Due to symmetry, it is enough to analyze the temperature distributions over a symmetry line. In this case, following experiment reported results, we take a south-to-north line in the fuel assembly. This one involves, in south to north ordering, subchannels 72, 49, 32, 20, 10, 4, 3, 2, 1, 7, 14, 26, 39, and 58.
Figure 1: Fuel pin and subchannel positions and numbering adopted for the Toshiba 37-pin benchmark. (a) Position and numbering of the heated pins with the subchannel center indicated with red dots. (b) Center position and numbering of the suchannels.
The characteristics of Toshiba's benchmark are provided in Table 1.
Table 1: Design and operational parameters for Toshiba's 37-pin benchmark.
| Experiment Parameter (unit) | Value |
| Number of pins (-) | |
| Pin Pitch (cm) | |
| Pin Diameter (cm) | |
| Wire wrap diameter (cm) | |
| Wire wrap axial pitch (cm) | |
| Flat-to-flat duct distance (cm) | |
| Inlet length (cm) | - |
| Heated length (cm) | |
| Outlet length (cm) | - |
| Outlet pressure (Pa) | |
| Inlet Temperature (K) | Experiment dependent |
| Power profile (-) | Chopped cosine (peaking factor ) |
Three flow configurations with reducing axial mass flow rate are selected for the validation exercise. These configurations are presented in Table 2.
Table 2: Validation cases selected in the Toshiba benchmark
| Naming | Run ID | Pin Power (W/cm) | Inlet temperature () | Flow rate (m/s) | Reynolds number |
| High flow rate | |||||
| Medium flow rate | |||||
| Low flow rate |
SCM Input
General Parameters
The general parameters on the experimental conditions are described here below. They set up the boundary conditions for the high-flow-rate test case.
T_in = 660
# [1e+6 kg/m^2-hour] turns into kg/m^2-sec
mass_flux_in = ${fparse 1e+6 * 37.00 / 36000.*0.5}
P_out = 2.0e5 # Pa
Mesh
The meshing in SCM uses a custom SCMTriAssemblyMeshGenerator. This one generates a mesh of 1D channel segments connected in 3D. The subchannel positions are automatically generated by specifying the number of radial rings, the flat to flat distance of the duct, and the pin pitch. The number of axial cells in which the domain is discretrized is specified by n_cells. For more information about the mesh generator, pelase consult the website documentation on SCM.
[TriSubChannelMesh<<<{"href": "../../../syntax/TriSubChannelMesh/index.html"}>>>]
[subchannel]
type = SCMTriAssemblyMeshGenerator<<<{"description": "Creates a mesh of 1D subchannels and 1D pins in a triangular lattice arrangement", "href": "../../../source/meshgenerators/SCMTriAssemblyMeshGenerator.html"}>>>
nrings<<<{"description": "Number of fuel-pin rings per assembly, counting the center pin as the first ring [-]"}>>> = 4
n_cells<<<{"description": "The number of cells in the axial direction"}>>> = 20
flat_to_flat<<<{"description": "Flat to flat distance for the hexagonal assembly [m]"}>>> = 0.085
heated_length<<<{"description": "Heated length [m]"}>>> = 1.0
pin_diameter<<<{"description": "Rod diameter [m]"}>>> = 0.01
pitch<<<{"description": "Pitch [m]"}>>> = 0.012
dwire<<<{"description": "Wire diameter [m]"}>>> = 0.002
hwire<<<{"description": "Wire lead length [m]"}>>> = 0.0833
spacer_z<<<{"description": "Axial location of spacers/vanes/mixing vanes [m]"}>>> = '0 0.2 0.4 0.6 0.8'
spacer_k<<<{"description": "K-loss coefficient of spacers/vanes/mixing vanes [-]"}>>> = '0.1 0.1 0.1 0.1 0.10'
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)FluidProperties
The FluidProperties block specifies the thermophysical properties used in the SCM solve. Sodium properties are used in this case.
[FluidProperties<<<{"href": "../../../syntax/FluidProperties/index.html"}>>>]
[sodium]
type = PBSodiumFluidProperties<<<{"description": "Class that provides the methods that realize the equations of state for Liquid Sodium", "href": "../../../source/fluidproperties/PBSodiumFluidProperties.html"}>>>
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)SubChannel
The SubChannel type specifies the solver to be used in the SCM solve. The type of problem used in this case is a liquid metal SCM problem that uses sodium fluid properties. The parameters beta and C_T are used are used to model the crossflow and cross enthalpy-fluxes. Different solve procedures can be applied. In this case, we use an implicit, non-segragated solve. For more information about the mesh generator, pelase consult the website documentation on SCM.
[SubChannel<<<{"href": "../../../syntax/SubChannel/index.html"}>>>]
type = TriSubChannel1PhaseProblem
fp = sodium
n_blocks = 1
P_out = 2.0e5
compute_density = true
compute_viscosity = true
compute_power = true
P_tol = 1.0e-6
T_tol = 1.0e-3
implicit = true
segregated = false
staggered_pressure = false
verbose_multiapps = true
verbose_subchannel = false
pin_HTC_closure = 'Dittus-Boelter'
# friction model
friction_closure = 'cheng'
full_output<<<{"description": "Add optional subchannel output variables"}>>> = true
mixing_closure = 'cheng_todreas'
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)Initial Conditions
This block specifies the initial conditions for the AuxVariables utilized in the SCM solve. The linear heat flux initialization requires an external file that defines the relative power per fuel pin. In this case, this file is name "pin_power_profile_37.txt"
[ICs<<<{"href": "../../../syntax/Cardinal/ICs/index.html"}>>>]
[q_prime_IC]
type = SCMTriPowerIC<<<{"description": "Computes axial power rate (W/m) assigned to the fuel pins in a triangular lattice arrangement", "href": "../../../source/ics/SCMTriPowerIC.html"}>>>
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = q_prime
power<<<{"description": "The postprocessor or Real to use for the total power of the subassembly [W]"}>>> = 1.000e5 # W
filename<<<{"description": "name of radial power profile .txt file (should be a single column) [UnitLess]."}>>> = "pin_power_profile_37.txt"
[Dpin_ic]
type = ConstantIC<<<{"description": "Sets a constant field value.", "href": "../../../source/ics/ConstantIC.html"}>>>
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = Dpin
value<<<{"description": "The value to be set in IC"}>>> = 0.01
[T_ic]
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = T
value<<<{"description": "The value to be set in IC"}>>> = ${T_in}
[P_ic]
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = P
[DP_ic]
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = DP
[Viscosity_ic]
type = ViscosityIC<<<{"description": "Computes viscosity from specified pressure and temperature", "href": "../../../source/ics/ViscosityIC.html"}>>>
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = mu
p<<<{"description": "Pressure [Pa]"}>>> = ${P_out}
T<<<{"description": "Temperature [K]"}>>> = T
fp<<<{"description": "Fluid properties user object name"}>>> = sodium
[rho_ic]
type = RhoFromPressureTemperatureIC<<<{"description": "Computes the density from pressure and temperature.", "href": "../../../source/ics/RhoFromPressureTemperatureIC.html"}>>>
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = rho
p<<<{"description": "The pressure [Pa]"}>>> = ${P_out}
T<<<{"description": "The temperature [K]"}>>> = T
fp<<<{"description": "The name of fluid properties user object."}>>> = sodium
[h_ic]
type = SpecificEnthalpyFromPressureTemperatureIC<<<{"description": "Computes the specific enthalpy from pressure and temperature.", "href": "../../../source/ics/SpecificEnthalpyFromPressureTemperatureIC.html"}>>>
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = h
[mdot_ic]
variable<<<{"description": "The variable this initial condition is supposed to provide values for."}>>> = mdot
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)Auxiliary Kernels
Auxiliary kernels are used to apply the boundary conditions on pressure, temperature, and mass flow rate.
[AuxKernels<<<{"href": "../../../syntax/AuxKernels/index.html"}>>>]
[T_in_bc]
type = ConstantAux<<<{"description": "Creates a constant field in the domain.", "href": "../../../source/auxkernels/ConstantAux.html"}>>>
variable<<<{"description": "The name of the variable that this object applies to"}>>> = T
boundary<<<{"description": "The list of boundaries (ids or names) from the mesh where this object applies"}>>> = inlet
value<<<{"description": "Some constant value that can be read from the input file"}>>> = ${T_in}
execute_on<<<{"description": "The list of flag(s) indicating when this object should be executed. For a description of each flag, see https://mooseframework.inl.gov/source/interfaces/SetupInterface.html."}>>> = 'timestep_begin'
[mdot_in_bc]
type = SCMMassFlowRateAux<<<{"description": "Computes mass flow rate from specified mass flux and subchannel cross-sectional area. Can read either PostprocessorValue or Real", "href": "../../../source/auxkernels/SCMMassFlowRateAux.html"}>>>
variable<<<{"description": "The name of the variable that this object applies to"}>>> = mdot
area<<<{"description": "Cross sectional area [m^2]"}>>> = S
mass_flux<<<{"description": "The postprocessor or Real to use for the value of mass_flux"}>>> = ${mass_flux_in}
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)Executioner
The executioner can be Steady or Transient. The tolerances are not used in the SCM problem.
[Executioner<<<{"href": "../../../syntax/Executioner/index.html"}>>>]
type = Steady
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)MultiApp system
A MultiApp is used for transfering the SCM solution into a detailed mesh.
[MultiApps<<<{"href": "../../../syntax/MultiApps/index.html"}>>>]
[viz]
type = FullSolveMultiApp<<<{"description": "Performs a complete simulation during each execution.", "href": "../../../source/multiapps/FullSolveMultiApp.html"}>>>
input_files<<<{"description": "The input file for each App. If this parameter only contains one input file it will be used for all of the Apps. When using 'positions_from_file' it is also admissable to provide one input_file per file."}>>> = "toshiba_37_pin_viz.i"
execute_on<<<{"description": "The list of flag(s) indicating when this object should be executed. For a description of each flag, see https://mooseframework.inl.gov/source/interfaces/SetupInterface.html."}>>> = "timestep_end"
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)A custom transfer, MultiAppDetailedSolutionTransfer, is used for this purpose.
[Transfers<<<{"href": "../../../syntax/Transfers/index.html"}>>>]
[subchannel_transfer]
type = SCMSolutionTransfer<<<{"description": "Transfers subchannel or pin solutions from a SubChannel mesh onto a visualization mesh.", "href": "../../../source/transfers/SCMSolutionTransfer.html"}>>>
to_multi_app<<<{"description": "The name of the MultiApp to transfer the data to"}>>> = viz
variable<<<{"description": "The auxiliary variables to transfer."}>>> = 'mdot SumWij P DP h T rho mu S'
[pin_transfer]
transfer_type<<<{"description": "Whether to transfer subchannel-centered or pin-centered fields."}>>> = pin
variable<<<{"description": "The auxiliary variables to transfer."}>>> = 'Tpin q_prime'
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)The detailed mesh uses a SCMDetailedTriAssemblyMeshGenerator and the solution variables are populated by the transfer.
[viz]
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)Results
An example flow distribution for the high flow-rate case is depicted in Figure 2. As graphically observed, a flat temperature profile is obtained in the bulk of the fuel assembly. In this experiment, the ratio of gap-distance to pitch produces a significantly larger mass flow in the outer subchannels as observed in Figure 2a. This causes the outer subchannnels to be significantly colder than the center ones. Thus, the expected temperature distribution is a flat distribution in the central region of the assembly with sharp drops next to the wrapper. Finally, it can be observed in Figures 2a and 2b that due to the significant difference between flow rates at the outer and center subchannel, there is a considerable flow development length in the entry to the fuel assembly. Inlet velocity conditions were unclear in the experiment report (Namekawa et al., 1984) and, hence, uniform mass flow at the inlet was assumed. If the assumption of uniform inlet flow rates turns out to be incorrect, a small deterioration of accuracy of the predicted outlet temperature can be expected. However, we observe that the flow rates fully develop before the outlet of the assembly, which suggests that this initial condition will have little effect over the analyzed temperature distribution at the outlet of the fuel assembly.
Figure 2: Example of simulation results for the high-flow test case in the Toshiba 37-pin benchmark. (a) Distribution of axial mass flow. (b) Distribution of lateral mass flow. (c) Distribution of temperature. (d) Distribution of dynamic viscosity due to heating.
The results obtained for the high-, medium-, and low-flow-rate validation cases are presented in Figure 3. We compare the results obtained with the present code with the ones obtained in the experiments and the SUBAC code (Sun et al., 2018). We have selected SUBAC for the code-to-code comparison since it is to our knowledge the subchannel code for wire-wrapped SFRs, with openly available results, that presented the best agreements between the code predictions and the experiment measurements for the current benchmark.
Figure 3: Comparison of results obtained for Toshiba 37-pin case between experimental measurements, the SUBAC code, and the current code. (a) High mass flow case. (b) Medium mass flow case. (c) Low mass flow case.
As observed in Figure 3, for the high mass flow rate case, the present model predicts results closer to the experimental results than SUBAC. This is expected, since the turbulent cross-flow calibration should still improve the prediction for the present case. However, when comparing the results predicted for the medium- and low-flow-rate cases in Figures 3b and 3c, respectively, we observe that our models over-predict the temperature distributions when compared to SUBAC. Further analysis determined that the more peaked distribution of temperatures predicted by SCM towards the center of the assembly may be produced by an over-prediction of the mixing rates, which yields larger than expected flows in the outer channels.
References
- F Namekawa, A Ito, and K Mawatari.
Buoyancy effects on wire-wrapped pin bundle heat transfer in an lmfbr fuel assembly.
In AIChE symposium series, volume 80, 128–133. 1984.[Export]
- RL Sun, DL Zhang, Y Liang, MJ Wang, WX Tian, SZ Qiu, and GH Su.
Development of a subchannel analysis code for sfr wire-wrapped fuel assemblies.
Progress in Nuclear Energy, 104:327–341, 2018.[Export]
