SCMTriAssemblyMeshGenerator
Creates a mesh of 1D subchannels and 1D pins in a triangular lattice arrangement
Overview
This mesh generator creates the 1D subchannel and pin meshes for a triangular lattice arrangement. The generated subdomains are named subchannel and fuel_pins. The center of the mesh is the origin.
This object replaces the old chained SCMTriSubChannelMeshGenerator and SCMTriPinMeshGenerator input pattern. See the SubChannel mesh generator migration page for old-to-new input examples.
Example Input File Syntax
[TriSubChannelMesh<<<{"href": "../../syntax/TriSubChannelMesh/index.html"}>>>]
  [subchannel]
    type = SCMTriAssemblyMeshGenerator<<<{"description": "Creates a mesh of 1D subchannels and 1D pins in a triangular lattice arrangement", "href": "SCMTriAssemblyMeshGenerator.html"}>>>
    pin_diameter<<<{"description": "Rod diameter [m]"}>>> = 0.01
    dwire<<<{"description": "Wire diameter [m]"}>>> = 0.002
    hwire<<<{"description": "Wire lead length [m]"}>>> = 0.0833
    spacer_z<<<{"description": "Axial location of spacers/vanes/mixing vanes [m]"}>>> = '0'
    spacer_k<<<{"description": "K-loss coefficient of spacers/vanes/mixing vanes [-]"}>>> = '5.0'
  [duct]
    type = SCMTriDuctMeshGenerator<<<{"description": "Creates a mesh of 2D duct cells around a triangular lattice subassembly", "href": "SCMTriDuctMeshGenerator.html"}>>>
    input<<<{"description": "The corresponding subchannel mesh"}>>> = subchannel
(contrib/moose/modules/subchannel/test/tests/problems/SFR/sodium-19pin/test19_monolithic.i)
Input Parameters
  • dwireWire diameter [m]
    C++ Type:Real
    Unit:(no unit assumed)
    Controllable:No
    Description:Wire diameter [m]
  • flat_to_flatFlat to flat distance for the hexagonal assembly [m]
    C++ Type:Real
    Controllable:No
    Description:Flat to flat distance for the hexagonal assembly [m]
  • heated_lengthHeated length [m]
    C++ Type:Real
    Controllable:No
    Description:Heated length [m]
  • hwireWire lead length [m]
    C++ Type:Real
    Controllable:No
    Description:Wire lead length [m]
  • n_cellsThe number of cells in the axial direction
    C++ Type:unsigned int
    Controllable:No
    Description:The number of cells in the axial direction
  • nringsNumber of fuel-pin rings per assembly, counting the center pin as the first ring [-]
    Controllable:No
    Description:Number of fuel-pin rings per assembly, counting the center pin as the first ring [-]
  • pin_diameterRod diameter [m]
    C++ Type:Real
    Controllable:No
    Description:Rod diameter [m]
  • pitchPitch [m]
    C++ Type:Real
    Controllable:No
    Description:Pitch [m]
Required Parameters
  • Kij0.5Lateral form loss coefficient [-]
    Default:0.5
    C++ Type:Real
    Controllable:No
    Description:Lateral form loss coefficient [-]
  • index_blockage0 index of subchannels affected by blockage
    Default:0
    C++ Type:std::vector<unsigned int>
    Controllable:No
    Description:index of subchannels affected by blockage
  • k_blockage0 Form loss coefficient of subchannels affected by blockage
    Default:0
    C++ Type:std::vector<Real>
    Controllable:No
    Description:Form loss coefficient of subchannels affected by blockage
  • pin_block_id1Fuel Pin block id
    Default:1
    Controllable:No
    Description:Fuel Pin block id
  • reduction_blockage1 Area reduction of subchannels affected by blockage (number to muliply the area)
    Default:1
    Controllable:No
    Description:Area reduction of subchannels affected by blockage (number to muliply the area)
  • spacer_kK-loss coefficient of spacers/vanes/mixing vanes [-]
    Controllable:No
    Description:K-loss coefficient of spacers/vanes/mixing vanes [-]
  • spacer_zAxial location of spacers/vanes/mixing vanes [m]
    Controllable:No
    Description:Axial location of spacers/vanes/mixing vanes [m]
  • subchannel_block_id0Subchannel block id
    Default:0
    Controllable:No
    Description:Subchannel block id
  • unheated_length_entry0Unheated length at entry [m]
    Default:0
    C++ Type:Real
    Controllable:No
    Description:Unheated length at entry [m]
  • unheated_length_exit0Unheated length at exit [m]
    Default:0
    C++ Type:Real
    Controllable:No
    Description:Unheated length at exit [m]
  • z_blockage0 0 axial location of blockage (inlet, outlet) [m]
    Default:0 0
    Controllable:No
    Description:axial location of blockage (inlet, outlet) [m]
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
