- id_nameExisting extra integer ID names that is used to generate a new extra integer ID by finding unique combinations of their values
C++ Type:std::vector<ExtraElementIDName>
Controllable:No
Description:Existing extra integer ID names that is used to generate a new extra integer ID by finding unique combinations of their values
- inputName of an existing mesh generator to which we assign extra element IDs
C++ Type:MeshGeneratorName
Controllable:No
Description:Name of an existing mesh generator to which we assign extra element IDs
- new_id_nameNew extra integer ID name
C++ Type:ExtraElementIDName
Controllable:No
Description:New extra integer ID name
UniqueExtraIDMeshGenerator
Add a new extra element integer ID by finding unique combinations of the existing extra element integer ID values
Overview
UniqueExtraIDMeshGenerator object applies a new set of extra IDs determined by parsing existing extra IDs. First, the existing extra IDs of each element are parsed to find a set of unique combinations of their ID values. Then, a new ID value are determined to individual unique combination and assign it to the corresponding element. The new ID is embedded in all the existing IDs, i.e. elements with a unique new ID value have a unique value for all existing IDs.
The UniqueExtraIDMeshGenerator requires the following parameters:
"id_name": list of existing extra ID names.
"new_id_name": name of the new extra ID name.
Optionally, users can control how the new ID values are determined by using "new_id_rule", which is a vector of unsigned integers. If "new_id_rule" is provided, new ID values are determined by multiplying the provided integers to the corresponding existing ID values and then summing the resulting values as: new_id_value = new_id_rule[0] * extra_id_value[0] + ... + new_id_rule[n] * extra_id_value[n].
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
[fmg]
type = FileMeshGenerator<<<{"description": "Read a mesh from a file.", "href": "FileMeshGenerator.html"}>>>
file<<<{"description": "The filename to read."}>>> = unique_id.e
exodus_extra_element_integers<<<{"description": "The variable names in the mesh file for loading extra element integers"}>>> = 'id1 id0'
[parse_id]
type = UniqueExtraIDMeshGenerator<<<{"description": "Add a new extra element integer ID by finding unique combinations of the existing extra element integer ID values", "href": "UniqueExtraIDMeshGenerator.html"}>>>
input<<<{"description": "Name of an existing mesh generator to which we assign extra element IDs"}>>> = fmg
id_name<<<{"description": "Existing extra integer ID names that is used to generate a new extra integer ID by finding unique combinations of their values"}>>> = 'id1 id0'
new_id_name<<<{"description": "New extra integer ID name"}>>> = 'parsed_id'
[](contrib/moose/test/tests/meshgenerators/unique_extra_id_mesh_generator/unique_id.i)Input Parameters
- new_id_ruleVector of unsigned integers to determine new integer ID values by multiplying the provided integers to the corresponding existing ID values and then summing the resulting values
C++ Type:std::vector<unsigned int>
Controllable:No
Description:Vector of unsigned integers to determine new integer ID values by multiplying the provided integers to the corresponding existing ID values and then summing the resulting values
- restricted_subdomainsOnly set new extra element id for elements in given subdomains
C++ Type:std::vector<SubdomainName>
Controllable:No
Description:Only set new extra element id for elements in given subdomains
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
