- inputsThe input MeshGenerators.
C++ Type:std::vector<MeshGeneratorName>
Controllable:No
Description:The input MeshGenerators.
- stitch_boundaries_pairsPairs of boundaries to be stitched together between the 1st mesh in inputs and each consecutive mesh
C++ Type:std::vector<std::vector<std::string>>
Controllable:No
Description:Pairs of boundaries to be stitched together between the 1st mesh in inputs and each consecutive mesh
StitchedMeshGenerator
Allows multiple mesh files to be stitched together to form a single mesh.
Example
Consider the following three meshes.
Fig. 1: Left portion of "stitched" mesh (left.e).
Fig. 2: Center portion of "stitched" mesh (center.e).
Fig. 3: Right portion of "stitched" mesh (right.e).
Using the StitchedMeshGenerator
object from within the Mesh block of the input file, as shown in the input file snippet below, these three square meshes are joined into a single mesh as shown in Figure 4.
Note that the way that the meshes are merged gives precedence to the left-most mesh listed in terms of sidesets: the sidesets of the second, third, etc meshes will be subsumed into the sidesets of the first mesh. The names of the sidesets in the first mesh are what the names that will remain in the outputted mesh.
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
[./fmg_left]
type = FileMeshGenerator<<<{"description": "Read a mesh from a file.", "href": "FileMeshGenerator.html"}>>>
file<<<{"description": "The filename to read."}>>> = left.e
[./fmg_center]
file<<<{"description": "The filename to read."}>>> = center.e
[./fmg_right]
file<<<{"description": "The filename to read."}>>> = right.e
[./smg]
type = StitchedMeshGenerator<<<{"description": "Allows multiple mesh files to be stitched together to form a single mesh.", "href": "StitchedMeshGenerator.html"}>>>
inputs<<<{"description": "The input MeshGenerators."}>>> = 'fmg_left fmg_center fmg_right'
clear_stitched_boundary_ids<<<{"description": "Whether or not to clear the stitched boundary IDs"}>>> = true
stitch_boundaries_pairs<<<{"description": "Pairs of boundaries to be stitched together between the 1st mesh in inputs and each consecutive mesh"}>>> = 'right left;
right left'
merge_boundaries_with_same_name<<<{"description": "If the input meshes have boundaries with the same name (but different IDs), merge them"}>>> = false
(contrib/moose/test/tests/meshgenerators/stitched_mesh_generator/stitched_mesh_generator.i)
Fig. 4: Resulting "stitched" mesh from combination of three square meshes.
Input Parameters
- algorithmBINARYControl the use of binary search for the nodes of the stitched surfaces.
Default:BINARY
C++ Type:MooseEnum
Controllable:No
Description:Control the use of binary search for the nodes of the stitched surfaces.
- clear_stitched_boundary_idsTrueWhether or not to clear the stitched boundary IDs
Default:True
C++ Type:bool
Controllable:No
Description:Whether or not to clear the stitched boundary IDs
- merge_boundaries_with_same_nameTrueIf the input meshes have boundaries with the same name (but different IDs), merge them
Default:True
C++ Type:bool
Controllable:No
Description:If the input meshes have boundaries with the same name (but different IDs), merge them
- prevent_boundary_ids_overlapTrueWhether to re-number boundaries in stitched meshes to prevent merging of unrelated boundaries
Default:True
C++ Type:bool
Controllable:No
Description:Whether to re-number boundaries in stitched meshes to prevent merging of unrelated boundaries
- subdomain_remappingTrueTreat input subdomain names as primary, preserving them and remapping IDs as needed
Default:True
C++ Type:bool
Controllable:No
Description:Treat input subdomain names as primary, preserving them and remapping IDs as needed
- verbose_stitchingFalseWhether mesh stitching should have verbose output.
Default:False
C++ Type:bool
Controllable:No
Description:Whether mesh stitching should have verbose output.
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
