SideSetsFromNodeSetsGenerator
Mesh generator which constructs side sets from node sets
Overview
This MeshGenerator object allows the user to make matching side sets for every existing node set. It does not delete or erase the original node sets in the process. A side may only be created from several nodes if the nodes are forming a side of an element.
For example, for a 2D element, nodes from the node set must be on the two edges of a vertex of an element to make this vertex be part of the created sideset. For a 3D hexagonal element, the four nodes on the corners of a face of an element must be part of the original node set to make the quadrilateral face be part of the created side set.
In the current implementation, this operation indiscriminately converts all node sets into side sets.
commentnote
This operation can also be performed automatically at the end of the mesh generation process if construct_side_list_from_node_list = true in the [Mesh] block.
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  construct_side_list_from_node_list<<<{"description": "If true, construct side lists from the nodesets in the mesh (i.e. if every node on a give side is in a nodeset then add that side to a sideset"}>>> = false  # set to false for testing purposes
  [gmg]
    type = GeneratedMeshGenerator<<<{"description": "Create a line, square, or cube mesh with uniformly spaced or biased elements.", "href": "GeneratedMeshGenerator.html"}>>>
    dim<<<{"description": "The dimension of the mesh to be generated"}>>> = 3
    nx<<<{"description": "Number of elements in the X direction"}>>> = 3
    ny<<<{"description": "Number of elements in the Y direction"}>>> = 3
    nz<<<{"description": "Number of elements in the Z direction"}>>> = 3
    xmax<<<{"description": "Upper X Coordinate of the generated mesh"}>>> = 3
    ymax<<<{"description": "Upper Y Coordinate of the generated mesh"}>>> = 3
    zmax<<<{"description": "Upper Z Coordinate of the generated mesh"}>>> = 3
  [bounding_box]
    type = BoundingBoxNodeSetGenerator<<<{"description": "Assigns all of the nodes either inside or outside of a bounding box to a new nodeset.", "href": "BoundingBoxNodeSetGenerator.html"}>>>
    input<<<{"description": "The mesh we want to modify"}>>> = gmg
    new_boundary<<<{"description": "The name of the nodeset to create"}>>> = 'nodes_to_convert_to_sides'
    top_right<<<{"description": "The bottom left point (in x,y,z with spaces in-between) of the box to select the nodes."}>>> = '2.1 2.1 1.1'
    bottom_left<<<{"description": "The bottom left point (in x,y,z with spaces in-between) of the box to select the nodes."}>>> = '-0.1 -0.1 -0.1'
  [create_sideset]
    type = SideSetsFromNodeSetsGenerator<<<{"description": "Mesh generator which constructs side sets from node sets", "href": "SideSetsFromNodeSetsGenerator.html"}>>>
    input<<<{"description": "Input mesh the operation will be applied to"}>>> = bounding_box
(contrib/moose/test/tests/meshgenerators/sidesets_from_nodesets_generator/from_nodes.i)
Input Parameters
  • inputInput mesh the operation will be applied to
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:Input mesh the operation will be applied to
Required Parameters
  • nodesets_to_convertIf specified, list of nodesets to convert. If not specified, all nodesets are converted
    C++ Type:std::vector<BoundaryName>
    Controllable:No
    Description:If specified, list of nodesets to convert. If not specified, all nodesets are converted
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
