- dwireWire diameter [m]
C++ Type:double
Unit:(no unit assumed)
Controllable:No
Description:Wire diameter [m]
- flat_to_flatFlat to flat distance for the hexagonal assembly [m]
C++ Type:double
Controllable:No
Description:Flat to flat distance for the hexagonal assembly [m]
- heated_lengthHeated length [m]
C++ Type:double
Controllable:No
Description:Heated length [m]
- hwireWire lead length [m]
C++ Type:double
Controllable:No
Description:Wire lead length [m]
- n_cellsThe number of cells in the axial direction
C++ Type:unsigned int
Controllable:No
Description:The number of cells in the axial direction
- nringsNumber of fuel Pin rings per assembly [-]
Controllable:No
Description:Number of fuel Pin rings per assembly [-]
- pin_diameterRod diameter [m]
C++ Type:double
Controllable:No
Description:Rod diameter [m]
- pitchPitch [m]
C++ Type:double
Controllable:No
Description:Pitch [m]
SCMTriSubChannelMeshGenerator
Creates a mesh of 1D subchannels in a triangular lattice arrangement
Overview
This mesh generator creates the mesh were the SCM solution variables associated with the subchannels live. The user needs to provide the "nrings" parameter which defines the number of fuel pin rings. For triangular sub-assemblies, one nring means that there is one central pin in the (0 0 0) position and six neighboring ones on the the vertices of a normal hexagon. The number of cells in the -z direction is given by "n_cells". The distance of the pins from eachother is given by the "pitch" parameter and the total length of the sub-assembly in the -z direction is defined by the parameters: "heated_length","unheated_length_entry","unheated_length_entry". The fuel pin diameter is given by "pin_diameter". The user also has the ability to define the effect of spacers or mixing vanes on the sub-assembly by defining their axial location "spacer_z" and a local presure from loss "spacer_k". "flat_to_flat" is the size of the hexagonal duct that encloses the sub-assembly. If the pins are wire wrapped then the parameters: "dwire" "hwire" have non zero values that describe the geometry of the wire-wrap. The center of the mesh is the origin.
Example Input File Syntax
[TriSubChannelMesh<<<{"href": "../../syntax/TriSubChannelMesh/index.html"}>>>]
[subchannel]
type = SCMTriSubChannelMeshGenerator<<<{"description": "Creates a mesh of 1D subchannels in a triangular lattice arrangement", "href": "SCMTriSubChannelMeshGenerator.html"}>>>
nrings<<<{"description": "Number of fuel Pin rings per assembly [-]"}>>> = 4
n_cells<<<{"description": "The number of cells in the axial direction"}>>> = 20
flat_to_flat<<<{"description": "Flat to flat distance for the hexagonal assembly [m]"}>>> = 0.085
heated_length<<<{"description": "Heated length [m]"}>>> = 1.0
pin_diameter<<<{"description": "Rod diameter [m]"}>>> = 0.01
pitch<<<{"description": "Pitch [m]"}>>> = 0.012
dwire<<<{"description": "Wire diameter [m]"}>>> = 0.002
hwire<<<{"description": "Wire lead length [m]"}>>> = 0.0833
spacer_z<<<{"description": "Axial location of spacers/vanes/mixing_vanes [m]"}>>> = '0 0.2 0.4 0.6 0.8'
spacer_k<<<{"description": "K-loss coefficient of spacers/vanes/mixing_vanes [-]"}>>> = '0.1 0.1 0.1 0.1 0.10'
[](contrib/moose/modules/subchannel/validation/Toshiba_37_pin/toshiba_37_pin.i)Input Parameters
- Kij0.5Lateral form loss coefficient [-]
Default:0.5
C++ Type:double
Controllable:No
Description:Lateral form loss coefficient [-]
- block_id0Domain Index
Default:0
Controllable:No
Description:Domain Index
- index_blockage0 index of subchannels affected by blockage
Default:0
C++ Type:std::vector<unsigned int>
Controllable:No
Description:index of subchannels affected by blockage
- k_blockage0 Form loss coefficient of subchannels affected by blockage
Default:0
C++ Type:std::vector<double>
Controllable:No
Description:Form loss coefficient of subchannels affected by blockage
- reduction_blockage1 Area reduction of subchannels affected by blockage (number to muliply the area)
Default:1
Controllable:No
Description:Area reduction of subchannels affected by blockage (number to muliply the area)
- spacer_kK-loss coefficient of spacers/vanes/mixing_vanes [-]
Controllable:No
Description:K-loss coefficient of spacers/vanes/mixing_vanes [-]
- spacer_zAxial location of spacers/vanes/mixing_vanes [m]
Controllable:No
Description:Axial location of spacers/vanes/mixing_vanes [m]
- unheated_length_entry0Unheated length at entry [m]
Default:0
C++ Type:double
Controllable:No
Description:Unheated length at entry [m]
- unheated_length_exit0Unheated length at exit [m]
Default:0
C++ Type:double
Controllable:No
Description:Unheated length at exit [m]
- z_blockage0 0 axial location of blockage (inlet, outlet) [m]
Default:0 0
Controllable:No
Description:axial location of blockage (inlet, outlet) [m]
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
