SCMTriDuctMeshGenerator
Creates a mesh of 2D duct cells around a triangular lattice subassembly
Overview
This mesh generator creates the mesh (with Quad4 elements) where the variables associated with the duct live.
The subdomain name used for the duct will match the name of this mesh generator.
AuxVariables
Defining this mesh automatically creates the auxvariables detailed here.
Example Input File Syntax
[TriSubChannelMesh<<<{"href": "../../syntax/TriSubChannelMesh/index.html"}>>>]
  [subchannel]
    type = SCMTriAssemblyMeshGenerator<<<{"description": "Creates a mesh of 1D subchannels and 1D pins in a triangular lattice arrangement", "href": "SCMTriAssemblyMeshGenerator.html"}>>>
    nrings<<<{"description": "Number of fuel-pin rings per assembly, counting the center pin as the first ring [-]"}>>> = 4
    n_cells<<<{"description": "The number of cells in the axial direction"}>>> = 100
    flat_to_flat<<<{"description": "Flat to flat distance for the hexagonal assembly [m]"}>>> = 0.085
    heated_length<<<{"description": "Heated length [m]"}>>> = 1.0
    pin_diameter<<<{"description": "Rod diameter [m]"}>>> = 0.01
    pitch<<<{"description": "Pitch [m]"}>>> = 0.012
    dwire<<<{"description": "Wire diameter [m]"}>>> = 0.002
    hwire<<<{"description": "Wire lead length [m]"}>>> = 0.0833
    spacer_z<<<{"description": "Axial location of spacers/vanes/mixing vanes [m]"}>>> = '0 0.2 0.4 0.6 0.8'
    spacer_k<<<{"description": "K-loss coefficient of spacers/vanes/mixing vanes [-]"}>>> = '0.1 0.1 0.1 0.1 0.10'
  [duct]
    type = SCMTriDuctMeshGenerator<<<{"description": "Creates a mesh of 2D duct cells around a triangular lattice subassembly", "href": "SCMTriDuctMeshGenerator.html"}>>>
    input<<<{"description": "The corresponding subchannel mesh"}>>> = subchannel
    nrings<<<{"description": "Number of fuel Pin rings in the assembly [-]"}>>> = 4
    pitch<<<{"description": "Pitch is the distance between adjacent pins [m]"}>>> = 0.012
(contrib/moose/modules/subchannel/examples/duct/test.i)
Input Parameters
  • flat_to_flatFlat to flat distance for the hexagonal assembly [m]
    C++ Type:double
    Unit:(no unit assumed)
    Controllable:No
    Description:Flat to flat distance for the hexagonal assembly [m]
  • heated_lengthHeated length [m]
    C++ Type:double
    Controllable:No
    Description:Heated length [m]
  • inputThe corresponding subchannel mesh
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:The corresponding subchannel mesh
  • n_cellsThe number of cells in the axial direction
    C++ Type:unsigned int
    Controllable:No
    Description:The number of cells in the axial direction
  • nringsNumber of fuel Pin rings in the assembly [-]
    Controllable:No
    Description:Number of fuel Pin rings in the assembly [-]
  • pitchPitch is the distance between adjacent pins [m]
    C++ Type:double
    Controllable:No
    Description:Pitch is the distance between adjacent pins [m]
Required Parameters
  • block_id2Domain Index
    Default:2
    Controllable:No
    Description:Domain Index
  • unheated_length_entry0Unheated length at entry [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at entry [m]
  • unheated_length_exit0Unheated length at exit [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at exit [m]
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
