- heated_lengthHeated length [m]
C++ Type:double
Unit:(no unit assumed)
Controllable:No
Description:Heated length [m]
- inputThe corresponding subchannel mesh
C++ Type:MeshGeneratorName
Controllable:No
Description:The corresponding subchannel mesh
- n_cellsThe number of cells in the axial direction
C++ Type:unsigned int
Controllable:No
Description:The number of cells in the axial direction
- nxNumber of subchannels in the x direction [-]
Controllable:No
Description:Number of subchannels in the x direction [-]
- nyNumber of subchannels in the y direction [-]
Controllable:No
Description:Number of subchannels in the y direction [-]
- pitchPitch [m]
C++ Type:double
Controllable:No
Description:Pitch [m]
SCMQuadPinMeshGenerator
Creates a mesh of 1D fuel pins in a square lattice arrangement
Overview
This mesh generator creates the mesh were the SCM solution variables associated with the fuel pins live. The user needs to provide the number of subchannels "nx" in the -x direction and "ny" in the -y direction. The number of cells in the -z direction is given by "n_cells". The distance of the pins from eachother is given by the "pitch" parameter and the total length of the pins in the -z direction is defined by the parameters: "heated_length","unheated_length_entry","unheated_length_exit". Last, "input" is a parameter that takes the name of an object of type SCMQuadSubChannelMeshGenerator so the user must be careful to define consistent parameters across both MeshGenerators. The center of the mesh is the origin.
Example Input File Syntax
[QuadSubChannelMesh<<<{"href": "../../syntax/QuadSubChannelMesh/index.html"}>>>]
[sub_channel]
type = SCMQuadSubChannelMeshGenerator<<<{"description": "Creates a mesh of 1D subchannels in a square lattice arrangement", "href": "SCMQuadSubChannelMeshGenerator.html"}>>>
nx<<<{"description": "Number of channels in the x direction [-]"}>>> = 6
ny<<<{"description": "Number of channels in the y direction [-]"}>>> = 6
n_cells<<<{"description": "The number of cells in the axial direction"}>>> = 20
pitch<<<{"description": "Pitch [m]"}>>> = 0.0126
pin_diameter<<<{"description": "Rod diameter [m]"}>>> = 0.00950
side_gap<<<{"description": "The side gap, not to be confused with the gap between pins, this refers to the gap next to the duct or else the distance between the subchannel centroid to the duct wall.distance(edge pin center, duct wall) = pitch / 2 + side_gap [m]"}>>> = 0.00095
heated_length<<<{"description": "Heated length [m]"}>>> = 3.658
spacer_z<<<{"description": "Axial location of spacers/vanes/mixing_vanes [m]"}>>> = '0.0 0.229 0.457 0.686 0.914 1.143 1.372 1.600 1.829 2.057 2.286 2.515 2.743 2.972 3.200 3.429'
spacer_k<<<{"description": "K-loss coefficient of spacers/vanes/mixing_vanes [-]"}>>> = '0.7 0.4 1.0 0.4 1.0 0.4 1.0 0.4 1.0 0.4 1.0 0.4 1.0 0.4 1.0 0.4'
[fuel_pins]
type = SCMQuadPinMeshGenerator<<<{"description": "Creates a mesh of 1D fuel pins in a square lattice arrangement", "href": "SCMQuadPinMeshGenerator.html"}>>>
input<<<{"description": "The corresponding subchannel mesh"}>>> = sub_channel
nx<<<{"description": "Number of subchannels in the x direction [-]"}>>> = 6
ny<<<{"description": "Number of subchannels in the y direction [-]"}>>> = 6
[](contrib/moose/modules/subchannel/validation/psbt/psbt_ss/psbt.i)Input Parameters
- block_id1Domain Index
Default:1
Controllable:No
Description:Domain Index
- unheated_length_entry0Unheated length at entry [m]
Default:0
C++ Type:double
Controllable:No
Description:Unheated length at entry [m]
- unheated_length_exit0Unheated length at exit [m]
Default:0
C++ Type:double
Controllable:No
Description:Unheated length at exit [m]
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
