- heated_lengthHeated length [m]
C++ Type:double
Unit:(no unit assumed)
Controllable:No
Description:Heated length [m]
- inputThe corresponding subchannel mesh
C++ Type:MeshGeneratorName
Controllable:No
Description:The corresponding subchannel mesh
- n_cellsThe number of cells in the axial direction
C++ Type:unsigned int
Controllable:No
Description:The number of cells in the axial direction
- side_gapGap between duct wall and outer pin lattice: distance(edge pin center, duct wall) = pitch/2 + side_gap [m]
C++ Type:double
Controllable:No
Description:Gap between duct wall and outer pin lattice: distance(edge pin center, duct wall) = pitch/2 + side_gap [m]
SCMQuadDuctMeshGenerator
Creates a mesh of 2D duct cells around a square-lattice subassembly
Overview
This mesh generator creates the mesh (with Quad4 elements) where the variables associated with the duct live.
The subdomain name used for the duct will match the name of this mesh generator.
Input Parameters
- block_id2Subdomain id for the duct mesh cells
Default:2
Controllable:No
Description:Subdomain id for the duct mesh cells
- nxNumber of channels in the x direction for the subchannel assembly. Must be more than 1 to built a duct[-]
Range:nx > 1
Controllable:No
Description:Number of channels in the x direction for the subchannel assembly. Must be more than 1 to built a duct[-]
- nyNumber of channels in the y direction for the subchannel assembly. Must be more than 1 to built a duct[-]
Range:ny > 1
Controllable:No
Description:Number of channels in the y direction for the subchannel assembly. Must be more than 1 to built a duct[-]
- pitchLattice pitch (must be positive)
C++ Type:double
Range:pitch > 0
Controllable:No
Description:Lattice pitch (must be positive)
- unheated_length_entry0Unheated length at entry [m]
Default:0
C++ Type:double
Controllable:No
Description:Unheated length at entry [m]
- unheated_length_exit0Unheated length at exit [m]
Default:0
C++ Type:double
Controllable:No
Description:Unheated length at exit [m]
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
