SCMQuadAssemblyMeshGenerator
Creates one mesh containing both 1D subchannels and 1D pins in a square lattice arrangement
Overview
This mesh generator creates the 1D subchannel and pin meshes for a square lattice arrangement. The generated subdomains are named subchannel and fuel_pins. The center of the mesh is the origin.
This object replaces the old chained SCMQuadSubChannelMeshGenerator and SCMQuadPinMeshGenerator input pattern. See the SubChannel mesh generator migration page for old-to-new input examples.
Example Input File Syntax
[QuadSubChannelMesh<<<{"href": "../../syntax/QuadSubChannelMesh/index.html"}>>>]
  [sub_channel]
    type = SCMQuadAssemblyMeshGenerator<<<{"description": "Creates one mesh containing both 1D subchannels and 1D pins in a square lattice arrangement", "href": "SCMQuadAssemblyMeshGenerator.html"}>>>
    nx<<<{"description": "Number of channels in the x direction [-]"}>>> = 6
    ny<<<{"description": "Number of channels in the y direction [-]"}>>> = 6
    n_cells<<<{"description": "The number of cells in the axial direction"}>>> = 10
    pitch<<<{"description": "Pitch [m]"}>>> = 0.0126
    pin_diameter<<<{"description": "Rod diameter [m]"}>>> = ${pin_diameter}
    side_gap<<<{"description": "The side gap, not to be confused with the gap between pins; this refers to the gap next to the duct or else the distance between the subchannel centroid and the duct wall. distance(edge pin center, duct wall) = pitch / 2 + side_gap [m]"}>>> = 0.00095
    heated_length<<<{"description": "Heated length [m]"}>>> = 1.0
    spacer_z<<<{"description": "Axial location of spacers/vanes/mixing vanes [m]"}>>> = '0.0'
    spacer_k<<<{"description": "K-loss coefficient of spacers/vanes/mixing vanes [-]"}>>> = '0.0'
(contrib/moose/modules/subchannel/test/tests/problems/psbt/psbt_explicit.i)
Input Parameters
  • heated_lengthHeated length [m]
    C++ Type:Real
    Unit:(no unit assumed)
    Controllable:No
    Description:Heated length [m]
  • n_cellsThe number of cells in the axial direction
    C++ Type:unsigned int
    Controllable:No
    Description:The number of cells in the axial direction
  • nxNumber of channels in the x direction [-]
    Controllable:No
    Description:Number of channels in the x direction [-]
  • nyNumber of channels in the y direction [-]
    Controllable:No
    Description:Number of channels in the y direction [-]
  • pin_diameterRod diameter [m]
    C++ Type:Real
    Controllable:No
    Description:Rod diameter [m]
  • pitchPitch [m]
    C++ Type:Real
    Controllable:No
    Description:Pitch [m]
  • side_gapThe side gap, not to be confused with the gap between pins; this refers to the gap next to the duct or else the distance between the subchannel centroid and the duct wall. distance(edge pin center, duct wall) = pitch / 2 + side_gap [m]
    C++ Type:Real
    Controllable:No
    Description:The side gap, not to be confused with the gap between pins; this refers to the gap next to the duct or else the distance between the subchannel centroid and the duct wall. distance(edge pin center, duct wall) = pitch / 2 + side_gap [m]
Required Parameters
  • Kij0.5Lateral form loss coefficient [-]
    Default:0.5
    C++ Type:Real
    Controllable:No
    Description:Lateral form loss coefficient [-]
  • index_blockage0 Index of subchannels affected by blockage
    Default:0
    C++ Type:std::vector<unsigned int>
    Controllable:No
    Description:Index of subchannels affected by blockage
  • k_blockage0 Form loss coefficient of blocked subchannels
    Default:0
    C++ Type:std::vector<Real>
    Controllable:No
    Description:Form loss coefficient of blocked subchannels
  • pin_block_id1Fuel Pin block id
    Default:1
    Controllable:No
    Description:Fuel Pin block id
  • reduction_blockage1 Area reduction of subchannels affected by blockage
    Default:1
    Controllable:No
    Description:Area reduction of subchannels affected by blockage
  • spacer_kK-loss coefficient of spacers/vanes/mixing vanes [-]
    Controllable:No
    Description:K-loss coefficient of spacers/vanes/mixing vanes [-]
  • spacer_zAxial location of spacers/vanes/mixing vanes [m]
    Controllable:No
    Description:Axial location of spacers/vanes/mixing vanes [m]
  • subchannel_block_id0Subchannel block id
    Default:0
    Controllable:No
    Description:Subchannel block id
  • unheated_length_entry0Unheated length at entry [m]
    Default:0
    C++ Type:Real
    Controllable:No
    Description:Unheated length at entry [m]
  • unheated_length_exit0Unheated length at exit [m]
    Default:0
    C++ Type:Real
    Controllable:No
    Description:Unheated length at exit [m]
  • z_blockage0 0 Axial location of blockage (inlet, outlet) [m]
    Default:0 0
    Controllable:No
    Description:Axial location of blockage (inlet, outlet) [m]
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
