SCMDetailedTriSubChannelMeshGenerator
Creates a detailed mesh of subchannels in a triangular lattice arrangement
Overview
This is a mesh generator used for visualization purposes only. It is part of an input file that creates a 3D realistic mesh of the subchannels in a triangular lattice arrangement. This input file has a Problem block with the NoSolveProblem because it is not used to perform any calculations. It is used to create a detailed 3D mesh that the SCM solution gets projected on. The center of the mesh is the origin.
Example Input File Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [subchannel]
    type = SCMDetailedTriSubChannelMeshGenerator<<<{"description": "Creates a detailed mesh of subchannels in a triangular lattice arrangement", "href": "SCMDetailedTriSubChannelMeshGenerator.html"}>>>
    nrings<<<{"description": "Number of fuel Pin rings per assembly [-]"}>>> = 3
    n_cells<<<{"description": "The number of cells in the axial direction"}>>> = 50
    flat_to_flat<<<{"description": "Flat to flat distance for the hexagonal assembly [m]"}>>> = 0.05319936
    heated_length<<<{"description": "Heated length [m]"}>>> = 0.87
    unheated_length_entry<<<{"description": "Unheated length at entry [m]"}>>> = 0.0
    unheated_length_exit<<<{"description": "Unheated length at exit [m]"}>>> = 0.402
    pin_diameter<<<{"description": "Rod diameter [m]"}>>> = 8.2e-3
    pitch<<<{"description": "Pitch [m]"}>>> = 0.01148
(contrib/moose/modules/subchannel/test/tests/problems/Lead-LBE-19pin/3D_LBE-19pin.i)
Input Parameters
  • flat_to_flatFlat to flat distance for the hexagonal assembly [m]
    C++ Type:double
    Unit:(no unit assumed)
    Controllable:No
    Description:Flat to flat distance for the hexagonal assembly [m]
  • heated_lengthHeated length [m]
    C++ Type:double
    Controllable:No
    Description:Heated length [m]
  • n_cellsThe number of cells in the axial direction
    C++ Type:unsigned int
    Controllable:No
    Description:The number of cells in the axial direction
  • nringsNumber of fuel Pin rings per assembly [-]
    Controllable:No
    Description:Number of fuel Pin rings per assembly [-]
  • pin_diameterRod diameter [m]
    C++ Type:double
    Controllable:No
    Description:Rod diameter [m]
  • pitchPitch [m]
    C++ Type:double
    Controllable:No
    Description:Pitch [m]
Required Parameters
  • block_id0Block ID used for the mesh subdomain.
    Default:0
    Controllable:No
    Description:Block ID used for the mesh subdomain.
  • unheated_length_entry0Unheated length at entry [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at entry [m]
  • unheated_length_exit0Unheated length at exit [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at exit [m]
  • verbose_flagFalseFlag to print out the mesh coordinates.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Flag to print out the mesh coordinates.
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
