SCMDetailedTriAssemblyMeshGenerator
Creates a detailed mesh of subchannels and pins in a triangular lattice arrangement
Overview
This mesh generator creates one detailed 3D visualization mesh containing both the subchannel volume and the fuel pin volume for a triangular lattice arrangement. The generated subdomains are named subchannel and fuel_pins.
This object replaces the old chained SCMDetailedTriSubChannelMeshGenerator and SCMDetailedTriPinMeshGenerator input pattern. See the SubChannel mesh generator migration page for old-to-new input examples.
Input Parameters
  • flat_to_flatFlat to flat distance for the hexagonal assembly [m]
    C++ Type:double
    Unit:(no unit assumed)
    Controllable:No
    Description:Flat to flat distance for the hexagonal assembly [m]
  • heated_lengthHeated length [m]
    C++ Type:double
    Controllable:No
    Description:Heated length [m]
  • n_cellsThe number of cells in the axial direction
    C++ Type:unsigned int
    Controllable:No
    Description:The number of cells in the axial direction
  • nringsNumber of fuel-pin rings per assembly, counting the center pin as the first ring [-]
    Controllable:No
    Description:Number of fuel-pin rings per assembly, counting the center pin as the first ring [-]
  • pin_diameterRod diameter [m]
    C++ Type:double
    Controllable:No
    Description:Rod diameter [m]
  • pitchPitch [m]
    C++ Type:double
    Controllable:No
    Description:Pitch [m]
Required Parameters
  • num_sectors16Number of azimuthal sectors used to discretize each circular pin cross section.
    Default:16
    Range:num_sectors>=4
    Controllable:No
    Description:Number of azimuthal sectors used to discretize each circular pin cross section.
  • pin_block_id1Fuel pin block id.
    Default:1
    Controllable:No
    Description:Fuel pin block id.
  • subchannel_block_id0Subchannel block id.
    Default:0
    Controllable:No
    Description:Subchannel block id.
  • unheated_length_entry0Unheated length at entry [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at entry [m]
  • unheated_length_exit0Unheated length at exit [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at exit [m]
  • verbose_flagFalseFlag to print out the mesh coordinates.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Flag to print out the mesh coordinates.
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
