SCMDetailedQuadSubChannelMeshGenerator
Creates a detailed mesh of subchannels in a square lattice arrangement
Overview
This is a mesh generator used for visualization purposes only. It is part of an input file that creates a 3D realistic mesh of the subchannels in a square lattice arrangement. This input file has a Problem block with the NoSolveProblem because it is not used to perform any calculations. It is used to create a detailed 3D mesh that the SCM solution gets projected on. The center of the mesh is the origin. Last the "side_gap" is an added distance between a perimetric pin and the duct, such that: distance(edge/corner pin center, duct wall) = pitch / 2 + side_gap.
Note that:
  • the vector (in the XY plane) from a corner pin center to the corner subchannel centroid is .
  • the vector (in the XY plane) from a corner pin center to the corner of the duct is .
Figure 1 presents a sketch of the SCM geometry nomenclature near the duct corner.
Geometric features of the quadrilateral SCM mesh
Figure 1: Geometric features of the quadrilateral SCM mesh
Input Parameters
  • heated_lengthHeated length [m]
    C++ Type:double
    Unit:(no unit assumed)
    Controllable:No
    Description:Heated length [m]
  • n_cellsThe number of cells in the axial direction
    C++ Type:unsigned int
    Controllable:No
    Description:The number of cells in the axial direction
  • nxNumber of channels in the x direction [-]
    Controllable:No
    Description:Number of channels in the x direction [-]
  • nyNumber of channels in the y direction [-]
    Controllable:No
    Description:Number of channels in the y direction [-]
  • pin_diameterRod diameter [m]
    C++ Type:double
    Controllable:No
    Description:Rod diameter [m]
  • pitchPitch [m]
    C++ Type:double
    Controllable:No
    Description:Pitch [m]
  • side_gapThe side gap, not to be confused with the gap between pins, this refers to the gap next to the duct or else the distance between the subchannel centroid to the duct wall.distance(edge pin center, duct wall) = pitch / 2 + side_gap [m]
    C++ Type:double
    Controllable:No
    Description:The side gap, not to be confused with the gap between pins, this refers to the gap next to the duct or else the distance between the subchannel centroid to the duct wall.distance(edge pin center, duct wall) = pitch / 2 + side_gap [m]
Required Parameters
  • block_id0Block ID used for the mesh subdomain.
    Default:0
    Controllable:No
    Description:Block ID used for the mesh subdomain.
  • unheated_length_entry0Unheated length at entry [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at entry [m]
  • unheated_length_exit0Unheated length at exit [m]
    Default:0
    C++ Type:double
    Controllable:No
    Description:Unheated length at exit [m]
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
