RenameBlockGenerator
Changes the block IDs and/or block names for a given set of blocks defined by either block ID or block name. The changes are independent of ordering. The merging of blocks is supported.
Renaming or Setting Block Names
When using the RenameBlockGenerator to change block names, the result is independent of ordering.
The following will change the name for the block meaningless to inside and will set the name for block 5 to outside:
[rename]
  type = RenameBlockGenerator
  input = some_mesh
  old_block = 'meaningless 5'
  new_block = 'inside outside'
Merging Blocks
The RenameBlockGenerator can be used to merge blocks together. The result is independent of ordering when "new_block" contains only block IDs. When "new_block" contains block names, the result is not necessarily independent of ordering.
The following will result in the merging of the elements in blocks 1, 2, and 3 into block 0:
[merge]
  input = some_mesh
  old_block = '1 2 3'
  new_block = '0 0 0'
As discussed previously, when providing names in "new_block", the result may be ordering-dependent. If a name is provided in "new_block" that does not already exist in the mesh, it will take the ID of the first rename.
Take the following examples (assuming that the block some_block does not exist yet):
[mergename0]
  input = some_mesh
  old_block = '0 1'
  new_block = 'some_block some_block'
[mergename1]
  input = some_mesh
  old_block = '1 0'
The result of each will be a block named some_block that contains elements that were in blocks 0 and 1. However, because the block some_block takes the ID of the first rename execution, the ID of some_block will be 0 in the case of the generator mergename0 and 1 in the case of the generator mergename1.
In the case of providing "new_block" by ID, the following examples (assuming that the block 2 does not exist yet) will have the same result:
[mergeblock0]
  input = some_mesh
  old_block = '0 1'
  new_block = '2 2'
[mergeblock1]
  input = some_mesh
  old_block = '1 0'
  new_block = '2 2'
That is, a block will be created with the ID 2 that contains the elements previously in blocks 0 and 1.
In summary, the possibility of ordering-dependent results with the RenameBlockGenerator depends on whether or not name(s) are provided in "new_block" and said name(s) do not exist yet.
Input Parameters
  • inputThe mesh we want to modify
    C++ Type:MeshGeneratorName
    Unit:(no unit assumed)
    Controllable:No
    Description:The mesh we want to modify
Required Parameters
  • new_blockThe new block ID(s)/name(s) to be given by the elements defined in 'old_block'.
    C++ Type:std::vector<SubdomainName>
    Controllable:No
    Description:The new block ID(s)/name(s) to be given by the elements defined in 'old_block'.
  • old_blockElements with these block ID(s)/name(s) will be given the new block information specified in 'new_block'
    Controllable:No
    Description:Elements with these block ID(s)/name(s) will be given the new block information specified in 'new_block'
Optional Parameters
  • control_tagsAdds user-defined labels for accessing object parameters via control logic.
    C++ Type:std::vector<std::string>
    Controllable:No
    Description:Adds user-defined labels for accessing object parameters via control logic.
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
