PolyLineMeshGenerator
Generates meshes from edges connecting a list of points.
Using the PolyLineMeshGenerator object from within the Mesh block of the input file will construct an open or closed (looped) one-dimensional manifold of Edge elements connecting each adjacent pair of points in a user-specified list. Points can live in 3-D space by default, but loops in the X-Y plane are particularly useful as inputs to subsequent triangulator mesh generators.
Example
The following Mesh block will connect the specified 3 points with a total of 9 Edge2 elements.
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [poly]
    type = PolyLineMeshGenerator<<<{"description": "Generates meshes from edges connecting a list of points.", "href": "PolyLineMeshGenerator.html"}>>>
    points<<<{"description": "The points defining the polyline, in order"}>>> = '-1.0 0.0 0.0
              1.0 1.0 1.0
              1.0 2.0 3.0'
    loop<<<{"description": "Whether edges should form a closed loop"}>>> = true
    nums_edges_between_points<<<{"description": "How many Edge elements to build between each point pair. If a single value is given, it is applied to all segments. Otherwise, the number of entries must match the number of segments."}>>> = 3
(contrib/moose/test/tests/meshgenerators/polyline_mesh_generator/polyline_mesh_generator_loop_refine.i)
Input Parameters
  • end_boundaryendBoundary to assign to (non-looped) polyline end
    Default:end
    C++ Type:BoundaryName
    Controllable:No
    Description:Boundary to assign to (non-looped) polyline end
  • loopFalseWhether edges should form a closed loop
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether edges should form a closed loop
  • nums_edges_between_points1 How many Edge elements to build between each point pair. If a single value is given, it is applied to all segments. Otherwise, the number of entries must match the number of segments.
    Default:1
    C++ Type:std::vector<unsigned int>
    Controllable:No
    Description:How many Edge elements to build between each point pair. If a single value is given, it is applied to all segments. Otherwise, the number of entries must match the number of segments.
  • pointsThe points defining the polyline, in order
    C++ Type:std::vector<libMesh::Point>
    Controllable:No
    Description:The points defining the polyline, in order
  • start_boundarystartBoundary to assign to (non-looped) polyline start
    Default:start
    Controllable:No
    Description:Boundary to assign to (non-looped) polyline start
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
