- id_nameName of extra integer ID set
C++ Type:std::string
Controllable:No
Description:Name of extra integer ID set
- inputThe mesh we want to modify
C++ Type:MeshGeneratorName
Controllable:No
Description:The mesh we want to modify
- plane_coordinatesCoordinates of planes along the axis. The origin are at x/y/z=0 depending on the axis
C++ Type:std::vector<double>
Unit:(no unit assumed)
Controllable:No
Description:Coordinates of planes along the axis. The origin are at x/y/z=0 depending on the axis
PlaneIDMeshGenerator
Adds an extra element integer that identifies planes in a mesh.
Overview
The PlaneIDMeshGenerator object applies an extra IDs to axial planes defined in a extruded mesh.
Extra ID Control
The PlaneIDMeshGenerator takes a mesh object and its axial layer structure as input. This axial plane structure given in "plane_coordinates" contains a list of coordinates defining each plane from bottom to top. If there are N planes, N+1 coordinate points should be defined here.
If each axial plane is uniformly sub-divided into multiple layers during the extrusion, distinct extra IDs can be optionally assigned to individual layers in each plane. "num_ids_per_plane" defines the number of unique IDs in each plane defined in "plane_coordinates".
Note that this generator only works for extruded geometries where the concept of axial layer is valid. The axis of plane can be specified using "plane_axis".
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
[pin2d]
type = ConcentricCircleMeshGenerator<<<{"description": "This ConcentricCircleMeshGenerator source code is to generate concentric circle meshes.", "href": "ConcentricCircleMeshGenerator.html"}>>>
num_sectors<<<{"description": "num_sectors % 2 = 0, num_sectors > 0Number of azimuthal sectors in each quadrant'num_sectors' must be an even number."}>>> = 2
radii<<<{"description": "Radii of major concentric circles"}>>> = '0.4 0.5'
rings<<<{"description": "Number of rings in each circle or in the enclosing square"}>>> = '1 1 1'
has_outer_square<<<{"description": "It determines if meshes for a outer square are added to concentric circle meshes."}>>> = on
pitch<<<{"description": "The enclosing square can be added to the completed concentric circle mesh.Elements are quad meshes."}>>> = 1.26
preserve_volumes<<<{"description": "Volume of concentric circles can be preserved using this function."}>>> = yes
smoothing_max_it<<<{"description": "Number of Laplacian smoothing iterations"}>>> = 3
[pin3d]
type = AdvancedExtruderGenerator<<<{"description": "Extrudes a 1D mesh into 2D, or a 2D mesh into 3D, and supports a variable height for each elevation, variable number of layers within each elevation, variable growth factors of axial element sizes within each elevation and remap subdomain_ids, boundary_ids and element extra integers within each elevation as well as interface boundaries between neighboring elevation layers, as well as following a 1D curve and modifying the radial (normal to the extrusion axis) extent of the geometry.", "href": "AdvancedExtruderGenerator.html"}>>>
input<<<{"description": "The mesh to extrude"}>>> = 'pin2d'
heights<<<{"description": "The height of each elevation"}>>> = '5.0 5.0 5.0'
direction<<<{"description": "A vector that points in the direction to extrude (note, this will be normalized internally - so don't worry about it here)"}>>> = '0 0 1'
num_layers<<<{"description": "The number of layers for each elevation - must be num_elevations in length!"}>>> = '2 2 2'
[pin3d_id]
type = PlaneIDMeshGenerator<<<{"description": "Adds an extra element integer that identifies planes in a mesh.", "href": "PlaneIDMeshGenerator.html"}>>>
input<<<{"description": "The mesh we want to modify"}>>> = 'pin3d'
plane_coordinates<<<{"description": "Coordinates of planes along the axis. The origin are at x/y/z=0 depending on the axis"}>>> = '0.0 5.0 10.0 15.0'
num_ids_per_plane<<<{"description": "Number of unique ids per plane"}>>> = ' 1 2 1'
plane_axis<<<{"description": "Axis of plane"}>>> = 'z'
id_name<<<{"description": "Name of extra integer ID set"}>>> = 'plane_id'
[](contrib/moose/test/tests/meshgenerators/plane_id_mesh_generator/plane_id_pin3d.i)Input Parameters
- num_ids_per_planeNumber of unique ids per plane
C++ Type:std::vector<unsigned int>
Controllable:No
Description:Number of unique ids per plane
- plane_axiszAxis of plane
Default:z
C++ Type:MooseEnum
Controllable:No
Description:Axis of plane
- tolerance0.0001Tolerance for plane coordinate check
Default:0.0001
C++ Type:double
Controllable:No
Description:Tolerance for plane coordinate check
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
