ParsedSubdomainMeshGenerator
Uses a parsed expression (combinatorial_geometry) to determine if an element (via its centroid) is inside the region defined by the expression and assigns a new block ID.
Example
The desired example mesh is a 1-by-1 2D square which contains Block 1 (a centered 0.8-by-0.8 square) and Block 2 (a 0.4-by-0.4 square located in the bottom left quarter of Block 1). The remaining edge of the square can be Block 0.
The combinatorial expression that defines Block 1 is below.
x > 0.1 & x < 0.9 & y > 0.1 & y < 0.9
The expression
x < 0.5 & y < 0.5
can partially define Block 2, but the region outside Block 1 also needs to be excluded. The input file syntax needed to generate this example is shown below.
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [gmg]
    type = GeneratedMeshGenerator<<<{"description": "Create a line, square, or cube mesh with uniformly spaced or biased elements.", "href": "GeneratedMeshGenerator.html"}>>>
    dim<<<{"description": "The dimension of the mesh to be generated"}>>> = 2
    nx<<<{"description": "Number of elements in the X direction"}>>> = 10
    ny<<<{"description": "Number of elements in the Y direction"}>>> = 10
    xmax<<<{"description": "Upper X Coordinate of the generated mesh"}>>> = 1
    ymax<<<{"description": "Upper Y Coordinate of the generated mesh"}>>> = 1
  [subdomains]
    type = ParsedSubdomainMeshGenerator<<<{"description": "Uses a parsed expression (`combinatorial_geometry`) to determine if an element (via its centroid) is inside the region defined by the expression and assigns a new block ID.", "href": "ParsedSubdomainMeshGenerator.html"}>>>
    input<<<{"description": "The mesh we want to modify"}>>> = gmg
    combinatorial_geometry<<<{"description": "Function expression encoding a combinatorial geometry"}>>> = 'x > 0.1 & x < 0.9 & y > 0.1 & y < 0.9'
    block_id<<<{"description": "Subdomain id to set for inside of the combinatorial"}>>> = 1
  [subdomains2]
    combinatorial_geometry<<<{"description": "Function expression encoding a combinatorial geometry"}>>> = 'x < 0.5 & y < 0.5'
    excluded_subdomains<<<{"description": "A set of subdomain names that will be immune to change if set. This cannot be used together with included_subdomains."}>>> = '0'
    block_id<<<{"description": "Subdomain id to set for inside of the combinatorial"}>>> = 2
    input<<<{"description": "The mesh we want to modify"}>>> = subdomains
(contrib/moose/test/tests/meshgenerators/parsed_subdomain_mesh_generator/parsed_subdomain_mg.i)
The final mesh output is:
A mesh with 3 subdomains, produced from the configurations given above.
Aside from ecluding some subdomains using "excluded_subdomains", users can also include only some subdomains using "included_subdomains". The two options are mutually exclusive.
Input Parameters
  • block_idSubdomain id to set for inside of the combinatorial
    C++ Type:unsigned short
    Controllable:No
    Description:Subdomain id to set for inside of the combinatorial
  • combinatorial_geometryFunction expression encoding a combinatorial geometry
    C++ Type:std::string
    Controllable:No
    Description:Function expression encoding a combinatorial geometry
  • inputThe mesh we want to modify
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:The mesh we want to modify
Required Parameters
  • block_nameSubdomain name to set for inside of the combinatorial
    C++ Type:SubdomainName
    Controllable:No
    Description:Subdomain name to set for inside of the combinatorial
  • constant_expressionsVector of values for the constants in constant_names (can be an FParser expression)
    C++ Type:std::vector<std::string>
    Controllable:No
    Description:Vector of values for the constants in constant_names (can be an FParser expression)
  • constant_namesVector of constants used in the parsed function
    Controllable:No
    Description:Vector of constants used in the parsed function
  • epsilon0Fuzzy comparison tolerance
    Default:0
    C++ Type:double
    Unit:(no unit assumed)
    Controllable:No
    Description:Fuzzy comparison tolerance
  • excluded_subdomainsA set of subdomain names that will be immune to change if set. This cannot be used together with included_subdomains.
    C++ Type:std::vector<SubdomainName>
    Controllable:No
    Description:A set of subdomain names that will be immune to change if set. This cannot be used together with included_subdomains.
  • extra_element_id_namesExtra element integers used in the parsed expression
    C++ Type:std::vector<ExtraElementIDName>
    Controllable:No
    Description:Extra element integers used in the parsed expression
  • included_subdomainsA set of subdomain names that will only be subjected to change if set. This cannot be used together with excluded_subdomains.
    Controllable:No
    Description:A set of subdomain names that will only be subjected to change if set. This cannot be used together with excluded_subdomains.
Optional Parameters
  • disable_fpoptimizerFalseDisable the function parser algebraic optimizer
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Disable the function parser algebraic optimizer
  • enable_ad_cacheTrueEnable caching of function derivatives for faster startup time
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Enable caching of function derivatives for faster startup time
  • enable_auto_optimizeTrueEnable automatic immediate optimization of derivatives
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Enable automatic immediate optimization of derivatives
  • enable_jitTrueEnable just-in-time compilation of function expressions for faster evaluation
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Enable just-in-time compilation of function expressions for faster evaluation
  • evalerror_behaviornanWhat to do if evaluation error occurs. Options are to pass a nan, pass a nan with a warning, throw a error, or throw an exception
    Default:nan
    C++ Type:MooseEnum
    Options:nan, nan_warning, error, exception
    Controllable:No
    Description:What to do if evaluation error occurs. Options are to pass a nan, pass a nan with a warning, throw a error, or throw an exception
Parsed Expression Advanced Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
