- block_idSubdomain id to set for inside/outside the bounding box
C++ Type:unsigned short
Controllable:No
Description:Subdomain id to set for inside/outside the bounding box
- centerThe center (many people spell this 'center') of the box.
C++ Type:libMesh::Point
Controllable:No
Description:The center (many people spell this 'center') of the box.
- heightThe height of the box
C++ Type:double
Unit:(no unit assumed)
Controllable:No
Description:The height of the box
- inputThe mesh we want to modify
C++ Type:MeshGeneratorName
Controllable:No
Description:The mesh we want to modify
- lengthThe length of the box
C++ Type:double
Controllable:No
Description:The length of the box
- length_directionThe direction along which the length is oriented (must be perpendicular to width_direction).
C++ Type:libMesh::VectorValue<double>
Controllable:No
Description:The direction along which the length is oriented (must be perpendicular to width_direction).
- widthThe width of the box
C++ Type:double
Controllable:No
Description:The width of the box
- width_directionThe direction along which the width is oriented.
Controllable:No
Description:The direction along which the width is oriented.
OrientedSubdomainBoundingBoxGenerator
Defines a subdomain inside or outside of a bounding box with arbitrary orientation.
Overview
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
[./gmg]
type = GeneratedMeshGenerator<<<{"description": "Create a line, square, or cube mesh with uniformly spaced or biased elements.", "href": "GeneratedMeshGenerator.html"}>>>
dim<<<{"description": "The dimension of the mesh to be generated"}>>> = 3
xmin<<<{"description": "Lower X Coordinate of the generated mesh"}>>> = -6
xmax<<<{"description": "Upper X Coordinate of the generated mesh"}>>> = 4
nx<<<{"description": "Number of elements in the X direction"}>>> = 10
ymin<<<{"description": "Lower Y Coordinate of the generated mesh"}>>> = -2
ymax<<<{"description": "Upper Y Coordinate of the generated mesh"}>>> = 10
ny<<<{"description": "Number of elements in the Y direction"}>>> = 12
zmin<<<{"description": "Lower Z Coordinate of the generated mesh"}>>> = -5
zmax<<<{"description": "Upper Z Coordinate of the generated mesh"}>>> = 7
nz<<<{"description": "Number of elements in the Z direction"}>>> = 12
[./subdomains]
type = OrientedSubdomainBoundingBoxGenerator<<<{"description": "Defines a subdomain inside or outside of a bounding box with arbitrary orientation.", "href": "OrientedSubdomainBoundingBoxGenerator.html"}>>>
input<<<{"description": "The mesh we want to modify"}>>> = gmg
center<<<{"description": "The center (many people spell this 'center') of the box."}>>> = '-1 4 1'
width<<<{"description": "The width of the box"}>>> = 5
length<<<{"description": "The length of the box"}>>> = 10
height<<<{"description": "The height of the box"}>>> = 4
width_direction<<<{"description": "The direction along which the width is oriented."}>>> = '2 1 0'
length_direction<<<{"description": "The direction along which the length is oriented (must be perpendicular to width_direction)."}>>> = '-1 2 2'
block_id<<<{"description": "Subdomain id to set for inside/outside the bounding box"}>>> = 10
[](contrib/moose/test/tests/meshgenerators/subdomain_bounding_box_generator/oriented_subdomain_bounding_box_generator.i)Input Parameters
- locationINSIDEControl of where the subdomain id is to be set
Default:INSIDE
C++ Type:MooseEnum
Controllable:No
Description:Control of where the subdomain id is to be set
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
