HexIDPatternedMeshGenerator
This mesh generator is deprecated. Please use a PatternedHexMeshGenerator.
Input Parameters
  • inputsThe input MeshGenerators.
    C++ Type:std::vector<MeshGeneratorName>
    Unit:(no unit assumed)
    Controllable:No
    Description:The input MeshGenerators.
  • patternA double-indexed hexagonal-shaped array starting with the upper-left corner.
    C++ Type:std::vector<std::vector<unsigned int>>
    Controllable:No
    Description:A double-indexed hexagonal-shaped array starting with the upper-left corner.
Required Parameters
  • duct_sizesDistance(s) from center to duct(s) inner boundaries.
    C++ Type:std::vector<double>
    Controllable:No
    Description:Distance(s) from center to duct(s) inner boundaries.
  • duct_sizes_styleapothemStyle in which hexagon center to duct distance(s) is given (apothem = center-to-face, radius = center-to-vertex).
    Default:apothem
    C++ Type:MooseEnum
    Options:apothem, radius
    Controllable:No
    Description:Style in which hexagon center to duct distance(s) is given (apothem = center-to-face, radius = center-to-vertex).
  • generate_core_metadataFalseA Boolean parameter that controls whether the core related metadata is generated for other MOOSE objects such as 'MultiControlDrumFunction' or not.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:A Boolean parameter that controls whether the core related metadata is generated for other MOOSE objects such as 'MultiControlDrumFunction' or not.
  • hexagon_sizeSize of the outmost hexagon boundary to be generated; this is required only when pattern type is 'hexagon'.
    C++ Type:double
    Controllable:No
    Description:Size of the outmost hexagon boundary to be generated; this is required only when pattern type is 'hexagon'.
  • hexagon_size_styleapothemStyle in which the hexagon size is given (default: apothem i.e. half-pitch).
    Default:apothem
    C++ Type:MooseEnum
    Controllable:No
    Description:Style in which the hexagon size is given (default: apothem i.e. half-pitch).
  • interface_boundary_id_shift_patternUser-defined shift values for each pattern cell. A double-indexed array starting with the upper-left corner.
    C++ Type:std::vector<std::vector<short>>
    Controllable:No
    Description:User-defined shift values for each pattern cell. A double-indexed array starting with the upper-left corner.
  • pattern_boundaryhexagonThe boundary shape of the patterned mesh.
    Default:hexagon
    C++ Type:MooseEnum
    Options:none, hexagon
    Controllable:No
    Description:The boundary shape of the patterned mesh.
  • rotate_angle90Rotate the entire patterned mesh by a certain degrees that is defined here.
    Default:90
    C++ Type:double
    Controllable:No
    Description:Rotate the entire patterned mesh by a certain degrees that is defined here.
Optional Parameters
  • assign_control_drum_idFalseWhether control drum id is assigned to the mesh as an extra integer.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether control drum id is assigned to the mesh as an extra integer.
  • generate_control_drum_positions_fileFalseWhether a positions file is generated in the core mesh mode.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether a positions file is generated in the core mesh mode.
  • position_filepositions_meta.dataData file name to store control drum positions.
    Default:positions_meta.data
    C++ Type:std::string
    Controllable:No
    Description:Data file name to store control drum positions.
Control Drum Parameters
  • assign_typecell List of integer ID assignment types
    Default:cell
    C++ Type:std::vector<MooseEnum>
    Options:cell, pattern, manual
    Controllable:No
    Description:List of integer ID assignment types
  • exclude_idName of input meshes to be excluded in ID generation
    Controllable:No
    Description:Name of input meshes to be excluded in ID generation
  • id_nameList of extra integer ID set names
    C++ Type:std::vector<std::string>
    Controllable:No
    Description:List of extra integer ID set names
  • id_patternUser-defined element IDs. A double-indexed array starting with the upper-left corner. When providing multiple patterns, each pattern should be separated using '|'
    C++ Type:std::vector<std::vector<std::vector<unsigned long, std::allocator<unsigned long>>>>
    Controllable:No
    Description:User-defined element IDs. A double-indexed array starting with the upper-left corner. When providing multiple patterns, each pattern should be separated using '|'
Reporting Id Parameters
  • background_block_idOptional customized block id for the background block in 'assembly' mode; must be provided along with 'duct_block_ids' if 'duct_sizes' is provided.
    C++ Type:unsigned short
    Controllable:No
    Description:Optional customized block id for the background block in 'assembly' mode; must be provided along with 'duct_block_ids' if 'duct_sizes' is provided.
  • background_block_nameOptional customized block name for the background block in 'assembly' mode; must be provided along with 'duct_block_names' if 'duct_sizes' is provided.
    C++ Type:SubdomainName
    Controllable:No
    Description:Optional customized block name for the background block in 'assembly' mode; must be provided along with 'duct_block_names' if 'duct_sizes' is provided.
  • boundary_region_element_typeQUAD4Type of the quadrilateral elements to be generated in the boundary region.
    Default:QUAD4
    C++ Type:MooseEnum
    Options:QUAD4, QUAD8, QUAD9
    Controllable:No
    Description:Type of the quadrilateral elements to be generated in the boundary region.
  • create_inward_interface_boundariesFalseWhether the inward interface boundary sidesets are created.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether the inward interface boundary sidesets are created.
  • create_outward_interface_boundariesTrueWhether the outward interface boundary sidesets are created.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Whether the outward interface boundary sidesets are created.
  • duct_block_idsOptional customized block ids for each duct geometry block in 'assembly' mode; must be provided along with 'background_block_id'.
    C++ Type:std::vector<unsigned short>
    Controllable:No
    Description:Optional customized block ids for each duct geometry block in 'assembly' mode; must be provided along with 'background_block_id'.
  • duct_block_namesOptional customized block names for each duct geometry block in 'assembly' mode; must be provided along with 'background_block_name'.
    C++ Type:std::vector<SubdomainName>
    Controllable:No
    Description:Optional customized block names for each duct geometry block in 'assembly' mode; must be provided along with 'background_block_name'.
  • external_boundary_idOptional customized external boundary id.
    C++ Type:short
    Controllable:No
    Description:Optional customized external boundary id.
  • external_boundary_nameOptional customized external boundary name.
    C++ Type:BoundaryName
    Controllable:No
    Description:Optional customized external boundary name.
Customized Subdomain/Boundary Parameters
  • background_intervals3Radial intervals in the assembly peripheral region.
    Default:3
    C++ Type:unsigned int
    Controllable:No
    Description:Radial intervals in the assembly peripheral region.
  • deform_non_circular_regionTrueWhether the non-circular region (outside the rings) can be deformed.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Whether the non-circular region (outside the rings) can be deformed.
  • duct_intervalsNumber of meshing intervals in each enclosing duct.
    C++ Type:std::vector<unsigned int>
    Controllable:No
    Description:Number of meshing intervals in each enclosing duct.
  • uniform_mesh_on_sidesFalseWhether the side elements are reorganized to have a uniform size.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether the side elements are reorganized to have a uniform size.
Mesh Density Parameters
  • control_tagsAdds user-defined labels for accessing object parameters via control logic.
    Controllable:No
    Description:Adds user-defined labels for accessing object parameters via control logic.
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
