FillBetweenCurvesGenerator
This FillBetweenCurvesGenerator object is designed to generate a transition layer to connect two boundaries of two input meshes.
Overview
The FillBetweenCurvesGenerator offers similar functionality to FillBetweenPointVectorsGenerator by leveraging FillBetweenPointVectorsTools. Instead of manually inputting the two boundaries "positions_vector_1" and "positions_vector_2", The FillBetweenCurvesGenerator directly takes boundary information from the two input meshes ("input_mesh_1" and "input_mesh_2") that contain the curve meshes consisting of Edge2 elements (e.g., generated by ParsedCurveGenerator). The input meshes can be translated using "mesh_1_shift" and "mesh_2_shift".
A typical example of using `FillBetweenCurvesGenerator` to connect a logarithmic curve and a circular curve.
Figure 1: A typical example of using FillBetweenCurvesGenerator to connect a logarithmic curve and a circular curve.
All the other meshing options are the same as FillBetweenPointVectorsGenerator.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [fbcg]
    type = FillBetweenCurvesGenerator<<<{"description": "This FillBetweenCurvesGenerator object is designed to generate a transition layer to connect two boundaries of two input meshes.", "href": "FillBetweenCurvesGenerator.html"}>>>
    input_mesh_1<<<{"description": "The input mesh that contains curve 1"}>>> = pcg1
    input_mesh_2<<<{"description": "The input mesh that contains curve 1"}>>> = pcg2
    num_layers<<<{"description": "Number of layers of elements created between the boundaries."}>>> = 3
    bias_parameter<<<{"description": "Parameter used to set up biasing of the layers: bias_parameter > 0.0 is used as the biasing factor; bias_parameter = 0.0 activates automatic biasing based on local node density on both input boundaries."}>>> = 0.0
(contrib/moose/test/tests/meshgenerators/fill_between_curves_generator/fill_between_curves.i)
Input Parameters
  • input_mesh_1The input mesh that contains curve 1
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:The input mesh that contains curve 1
  • input_mesh_2The input mesh that contains curve 1
    Controllable:No
  • num_layersNumber of layers of elements created between the boundaries.
    C++ Type:unsigned int
    Range:num_layers>0
    Controllable:No
    Description:Number of layers of elements created between the boundaries.
Required Parameters
  • begin_side_boundary_id10000Boundary ID to be assigned to the boundary connecting starting points of the positions_vectors.
    Default:10000
    C++ Type:short
    Controllable:No
    Description:Boundary ID to be assigned to the boundary connecting starting points of the positions_vectors.
  • bias_parameter1Parameter used to set up biasing of the layers: bias_parameter > 0.0 is used as the biasing factor; bias_parameter = 0.0 activates automatic biasing based on local node density on both input boundaries.
    Default:1
    C++ Type:double
    Unit:(no unit assumed)
    Range:bias_parameter>=0
    Controllable:No
    Description:Parameter used to set up biasing of the layers: bias_parameter > 0.0 is used as the biasing factor; bias_parameter = 0.0 activates automatic biasing based on local node density on both input boundaries.
  • block_id1ID to be assigned to the transition layer.
    Default:1
    C++ Type:unsigned short
    Controllable:No
    Description:ID to be assigned to the transition layer.
  • end_side_boundary_id10000Boundary ID to be assigned to the boundary connecting ending points of the positions_vectors.
    Default:10000
    C++ Type:short
    Controllable:No
    Description:Boundary ID to be assigned to the boundary connecting ending points of the positions_vectors.
  • gaussian_sigma3Gaussian parameter used to smoothen local node density for automatic biasing; this parameter is not used if another biasing option is selected.
    Default:3
    C++ Type:double
    Range:gaussian_sigma>0.0
    Controllable:No
    Description:Gaussian parameter used to smoothen local node density for automatic biasing; this parameter is not used if another biasing option is selected.
  • input_boundary_1_id10000Boundary ID to be assigned to the boundary defined by positions_vector_1.
    Default:10000
    C++ Type:short
    Controllable:No
    Description:Boundary ID to be assigned to the boundary defined by positions_vector_1.
  • input_boundary_2_id10000Boundary ID to be assigned to the boundary defined by positions_vector_2.
    Default:10000
    C++ Type:short
    Controllable:No
    Description:Boundary ID to be assigned to the boundary defined by positions_vector_2.
  • mesh_1_shift0 0 0Translation vector to be applied to input_mesh_1
    Default:0 0 0
    C++ Type:libMesh::Point
    Controllable:No
    Description:Translation vector to be applied to input_mesh_1
  • mesh_2_shift0 0 0Translation vector to be applied to input_mesh_2
    Default:0 0 0
    Controllable:No
    Description:Translation vector to be applied to input_mesh_2
  • use_quad_elementsFalseWhether QUAD4 instead of TRI3 elements are used to construct the transition layer.
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether QUAD4 instead of TRI3 elements are used to construct the transition layer.
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
