- inputThe mesh we want to modify
C++ Type:MeshGeneratorName
Unit:(no unit assumed)
Controllable:No
Description:The mesh we want to modify
- source_extra_element_idThe extra element ID to be copied
C++ Type:std::string
Controllable:No
Description:The extra element ID to be copied
- target_extra_element_idsThe target extra element IDs
C++ Type:std::vector<std::string>
Controllable:No
Description:The target extra element IDs
ExtraElementIDCopyGenerator
Copy an extra element ID to other extra element IDs.
Overview
The ExtraElementIDCopyGenerator
is used to copy an extra element ID to other extra element IDs. If the target extra element IDs do not exist in the input mesh, they will be added by this mesh generator before copying. The extra element ID name subdomain_id is reserved for the subdomain ID and can be used as the name of the source extra element ID, but not as the target extra element ID. The extra element ID name element_id is reserved for the element ID and can be used as the name of the source extra element ID, but not as the target extra element ID.
Input Parameters
- control_tagsAdds user-defined labels for accessing object parameters via control logic.
Controllable:No
Description:Adds user-defined labels for accessing object parameters via control logic.
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
