DistributedRectilinearMeshGenerator
Create a line, square, or cube mesh with uniformly spaced or biased elements.
Overview
Similar to GeneratedMeshGenerator - builds lines, rectangles and rectangular prisms. It differs though in the way the mesh is constructed in parallel. While GeneratedMeshGenerator creates a full copy of the mesh on every processor - DistributedRectilinearMeshGenerator only creates the elements / nodes each processor is assigned. This makes it _much_ faster in parallel and much leaner in memory.
commentnote
Be aware: DistributedRectilinearMeshGenerator turns on parallel_type = distributed. So make sure that everything you're using in your problem works with that before using this!
More Information
DistributedRectilinearMeshGenerator works by first creating a "dual graph" of the element connectivity - before ever building an elements. It then uses PetscExternalPartitioner to partition that graph - assigning elements to processors. Then, each processor can read the partition map and build only the elements that need to be on that processor. Final steps include adding in "ghosted" elements and making sure that boundary conditions are right.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [gmg]
    type = DistributedRectilinearMeshGenerator<<<{"description": "Create a line, square, or cube mesh with uniformly spaced or biased elements.", "href": "DistributedRectilinearMeshGenerator.html"}>>>
    dim<<<{"description": "The dimension of the mesh to be generated"}>>> = 2
    nx<<<{"description": "Number of elements in the X direction"}>>> = 100
    ny<<<{"description": "Number of elements in the Y direction"}>>> = 100
(contrib/moose/test/tests/meshgenerators/distributed_rectilinear/generator/distributed_rectilinear_mesh_generator.i)
Input Parameters
  • dimThe dimension of the mesh to be generated
    C++ Type:MooseEnum
    Options:1, 2, 3
    Controllable:No
    Description:The dimension of the mesh to be generated
Required Parameters
  • apply_element_weightFalseIndicate if we are going to apply element weights to partitioners
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Indicate if we are going to apply element weights to partitioners
  • apply_side_weightFalseIndicate if we are going to apply side weights to partitioners
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Indicate if we are going to apply side weights to partitioners
  • bias_x1The amount by which to grow (or shrink) the cells in the x-direction.
    Default:1
    C++ Type:double
    Unit:(no unit assumed)
    Range:bias_x>=0.5 & bias_x<=2
    Controllable:No
    Description:The amount by which to grow (or shrink) the cells in the x-direction.
  • bias_y1The amount by which to grow (or shrink) the cells in the y-direction.
    Default:1
    C++ Type:double
    Range:bias_y>=0.5 & bias_y<=2
    Controllable:No
    Description:The amount by which to grow (or shrink) the cells in the y-direction.
  • bias_z1The amount by which to grow (or shrink) the cells in the z-direction.
    Default:1
    C++ Type:double
    Range:bias_z>=0.5 & bias_z<=2
    Controllable:No
    Description:The amount by which to grow (or shrink) the cells in the z-direction.
  • elem_typeThe type of element from libMesh to generate (default: linear element for requested dimension)
    C++ Type:MooseEnum
    Options:EDGE2, QUAD4, HEX8
    Controllable:No
    Description:The type of element from libMesh to generate (default: linear element for requested dimension)
  • num_cores_for_partition0Number of cores for partitioning the graph
    Default:0
    C++ Type:unsigned int
    Controllable:No
    Description:Number of cores for partitioning the graph
  • num_cores_per_compute_node1Number of cores per compute node for hierarchical partitioning
    Default:1
    Controllable:No
    Description:Number of cores per compute node for hierarchical partitioning
  • num_side_layers2Number of layers of off-processor side neighbors is reserved during mesh generation
    Default:2
    Range:num_side_layers>=1 & num_side_layers<5
    Controllable:No
    Description:Number of layers of off-processor side neighbors is reserved during mesh generation
  • nx1Number of elements in the X direction
    Default:1
    C++ Type:unsigned long
    Controllable:No
    Description:Number of elements in the X direction
  • ny1Number of elements in the Y direction
    Default:1
    Controllable:No
    Description:Number of elements in the Y direction
  • nz1Number of elements in the Z direction
    Default:1
    Controllable:No
    Description:Number of elements in the Z direction
  • part_packageparmetisThe external package is used for partitioning the mesh via PETSc
    Default:parmetis
    C++ Type:MooseEnum
    Options:parmetis, ptscotch, chaco, party, hierarch
    Controllable:No
    Description:The external package is used for partitioning the mesh via PETSc
  • partitiongraphWhich method (graph linear square) use to partition mesh
    Default:graph
    C++ Type:MooseEnum
    Options:graph, linear, square
    Controllable:No
    Description:Which method (graph linear square) use to partition mesh
  • xmax1Upper X Coordinate of the generated mesh
    Default:1
    C++ Type:double
    Controllable:No
    Description:Upper X Coordinate of the generated mesh
  • xmin0Lower X Coordinate of the generated mesh
    Default:0
    C++ Type:double
    Controllable:No
    Description:Lower X Coordinate of the generated mesh
  • ymax1Upper Y Coordinate of the generated mesh
    Default:1
    C++ Type:double
    Controllable:No
    Description:Upper Y Coordinate of the generated mesh
  • ymin0Lower Y Coordinate of the generated mesh
    Default:0
    C++ Type:double
    Controllable:No
    Description:Lower Y Coordinate of the generated mesh
  • zmax1Upper Z Coordinate of the generated mesh
    Default:1
    C++ Type:double
    Controllable:No
    Description:Upper Z Coordinate of the generated mesh
  • zmin0Lower Z Coordinate of the generated mesh
    Default:0
    C++ Type:double
    Controllable:No
    Description:Lower Z Coordinate of the generated mesh
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
