DepletionIDGenerator
This DepletionIDGenerator source code is to assign an extra element integer for elements on a mesh based on material and other extra element IDs that is typically used for depletion.
Overview
DepletionIDGenerator object generates and assigns depletion IDs (extra element integers) on a mesh by finding unique combinations of reporting and material IDs. For a pin-level depletion case, the individual pins can be identified by the pin and assembly IDs, and the detailed depletion regions within a pin can be further divided by material IDs. For assembly-wise depletion, the user can set up the depletion IDs by combining the assembly and material IDs. Once the detailed depletion regions are determined, depletion IDs are uniquely assigned to those resulting regions.
Depletion ID Control
"id_name" lists extra element integer ID names used for setting up the depletion zones. Note that the material ID does not need to be defined in the list because it is included by default. A depletion zone (elements with the same depletion id) is always covered by one material region (elements with the same material id). The level of details in depletion zones can be controlled by the extra element integer IDs defined in "id_name". Any different combination of extra element integer IDs is considered a unique depletion zone.
For example, one can set up pin-by-pin and axial layer-by-layer arrangement of depletion zone by specifying those three reporting IDs: pin, assembly and plane IDs.
An alternative extra element integer ID name for the material ID can be optionally specified in "material_id_name". Its default value is set to material_id.
A list of extra element integer ID can be provided in "exclude_id_name" and "exclude_id_value" to exclude certain domains from being assigned depletion IDs. For those domains specified in "exclude_id_name" and "exclude_id_value", the depletion ID is set to zero because the depletion ID must be assigned for every mesh element even if not used in the actual depletion calculation.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
  [fmg]
    type = FileMeshGenerator<<<{"description": "Read a mesh from a file.", "href": "FileMeshGenerator.html"}>>>
    file<<<{"description": "The filename to read."}>>> = depletion_id_in.e
    exodus_extra_element_integers<<<{"description": "The variable names in the mesh file for loading extra element integers"}>>> = 'material_id pin_id assembly_id'
  [depl_map]
    type = DepletionIDGenerator<<<{"description": "This DepletionIDGenerator source code is to assign an extra element integer for elements on a mesh based on material and other extra element IDs that is typically used for depletion.", "href": "DepletionIDGenerator.html"}>>>
    input<<<{"description": "Name of an existing mesh generator to which we assign element IDs"}>>> = 'fmg'
    id_name<<<{"description": "Extra integer id names"}>>> = 'assembly_id pin_id'
    material_id_name<<<{"description": "Material id name"}>>> = 'material_id'
(contrib/moose/modules/reactor/test/tests/meshgenerators/reporting_id/depletion_id/depletion_id.i)
Input Parameters
  • inputName of an existing mesh generator to which we assign element IDs
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:Name of an existing mesh generator to which we assign element IDs
Required Parameters
  • exclude_id_nameExtra ID names that need to be excluded in the depletion ID generation
    C++ Type:std::vector<ExtraElementIDName>
    Controllable:No
    Description:Extra ID names that need to be excluded in the depletion ID generation
  • exclude_id_valueExtra ID values corresponding to names defined in `exclude_id_name`
    C++ Type:std::vector<std::vector<unsigned long>>
    Controllable:No
    Description:Extra ID values corresponding to names defined in `exclude_id_name`
  • exclude_material_idDefine a list of material IDs to be excluded in the depletion ID generation
    C++ Type:std::vector<unsigned long>
    Controllable:No
    Description:Define a list of material IDs to be excluded in the depletion ID generation
  • generated_id_namedepletion_idThe generated extra element integer name
    Default:depletion_id
    C++ Type:ExtraElementIDName
    Controllable:No
    Description:The generated extra element integer name
  • id_nameExtra integer id names
    Controllable:No
    Description:Extra integer id names
  • material_id_namematerial_idMaterial id name
    Default:material_id
    Controllable:No
    Description:Material id name
Optional Parameters
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
