- coarse_meshName of an existing mesh generator as the coarse mesh
C++ Type:MeshGeneratorName
Unit:(no unit assumed)
Controllable:No
Description:Name of an existing mesh generator as the coarse mesh
- extra_element_id_nameName for the extra element ID that is added to the input mesh
C++ Type:std::string
Controllable:No
Description:Name for the extra element ID that is added to the input mesh
- inputName of an existing mesh generator to which we assign coarse element IDs
Controllable:No
Description:Name of an existing mesh generator to which we assign coarse element IDs
CoarseMeshExtraElementIDGenerator
Assign coarse element IDs for elements on a mesh based on a coarse mesh.
Overview
This mesh generator adds an extra element integer to an input mesh based on a coarse mesh. The extra element integer of an element on the input mesh is assigned with the element ID of the coarse element containing the centroid of the fine element by default. Users can use the "coarse_mesh_extra_element_id" parameter to use an extra element ID on the coarse mesh for the assignment instead of the default coarse element ID. A reserved name subdomain_id can be used for "coarse_mesh_extra_element_id" for using the subdomain ID on the coarse mesh. Users can optionally check if the fine mesh is embedded in the coarse mesh using the "enforce_mesh_embedding" parameter, i.e. every element on the fine mesh must be contained within one and only one coarse element or a region by "coarse_mesh_extra_element_id" of the coarse mesh. The extra element ID assignment can be restricted to subdomains in the fine mesh by specifying "subdomains". With this parameter, this mesh generator can be called multiple times with different coarse meshes. After the first assignment, subsequent IDs will be offset by the maximum ID found from previous calls.
Input Parameters
- coarse_mesh_extra_element_idName for the extra element ID that is copied from the coarse mesh (default to element ID)
Controllable:No
Description:Name for the extra element ID that is copied from the coarse mesh (default to element ID)
- enforce_mesh_embeddingFalseTrue to error out when the input mesh is not embedded in the coarse mesh
Default:False
C++ Type:bool
Controllable:No
Description:True to error out when the input mesh is not embedded in the coarse mesh
- subdomainsSubdomains to apply extra element IDs to.
C++ Type:std::vector<SubdomainName>
Controllable:No
Description:Subdomains to apply extra element IDs to.
Optional Parameters
- control_tagsAdds user-defined labels for accessing object parameters via control logic.
C++ Type:std::vector<std::string>
Controllable:No
Description:Adds user-defined labels for accessing object parameters via control logic.
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
