- dimThe dimension of the mesh to be generated
C++ Type:MooseEnum
Controllable:No
Description:The dimension of the mesh to be generated
- dxIntervals in the X direction
C++ Type:std::vector<Real>
Unit:(no unit assumed)
Controllable:No
Description:Intervals in the X direction
CartesianMeshGenerator
This CartesianMeshGenerator creates a non-uniform Cartesian mesh.
Overview
The CartesianMeshGenerator object is the built-in mesh generation capable of creating lines, rectangles, and hexahedra ("boxes"). The mesh spacing can be non-uniform and each line/rectangle/hexahedron can be assigned a separate subdomain id. The mesh automatically creates side sets that are logically named and numbered as follows:
In 1D, left = 0, right = 1
In 2D, bottom = 0, right = 1, top = 2, left = 3
In 3D, back = 0, bottom = 1, right = 2, top = 3, left = 4, front = 5
The length, width, and height of each element, as well as their subdomain id can be set independently. Each linear subdivision in x, y, or z can be additionally subdivided into sub-elements.
Example Syntax
[Mesh<<<{"href": "../../syntax/Mesh/index.html"}>>>]
[./cmg]
type = CartesianMeshGenerator<<<{"description": "This CartesianMeshGenerator creates a non-uniform Cartesian mesh.", "href": "CartesianMeshGenerator.html"}>>>
dim<<<{"description": "The dimension of the mesh to be generated"}>>> = 3
dx<<<{"description": "Intervals in the X direction"}>>> = '1.5 2.4 0.1'
dy<<<{"description": "Intervals in the Y direction (required when dim>1 otherwise ignored)"}>>> = '1.3 0.9'
dz<<<{"description": "Intervals in the Z direction (required when dim>2 otherwise ignored)"}>>> = '0.4 0.5 0.6 0.7'
ix<<<{"description": "Number of grids in all intervals in the X direction (default to all one)"}>>> = '2 1 1'
iy<<<{"description": "Number of grids in all intervals in the Y direction (default to all one)"}>>> = '2 3'
iz<<<{"description": "Number of grids in all intervals in the Z direction (default to all one)"}>>> = '1 1 1 1'
subdomain_id<<<{"description": "Block IDs (default to all zero)"}>>> = '0 1 1
2 2 2
3 4 4
5 5 5
0 1 1
2 2 2
3 4 4
5 5 5
[](contrib/moose/test/tests/meshgenerators/cartesian_mesh_generator/cartesian_mesh_3D.i)Input Parameters
- dyIntervals in the Y direction (required when dim>1 otherwise ignored)
Controllable:No
Description:Intervals in the Y direction (required when dim>1 otherwise ignored)
- dzIntervals in the Z direction (required when dim>2 otherwise ignored)
Controllable:No
Description:Intervals in the Z direction (required when dim>2 otherwise ignored)
- ixNumber of grids in all intervals in the X direction (default to all one)
C++ Type:std::vector<unsigned int>
Controllable:No
Description:Number of grids in all intervals in the X direction (default to all one)
- iyNumber of grids in all intervals in the Y direction (default to all one)
Controllable:No
Description:Number of grids in all intervals in the Y direction (default to all one)
- izNumber of grids in all intervals in the Z direction (default to all one)
Controllable:No
Description:Number of grids in all intervals in the Z direction (default to all one)
- max_sizes_in_xMaximum element size in the X direction. This can be specified once for all 'dx' intervals or specified for each interval. 'ix' is then determined using the ceiling of dx/size
Controllable:No
Description:Maximum element size in the X direction. This can be specified once for all 'dx' intervals or specified for each interval. 'ix' is then determined using the ceiling of dx/size
- max_sizes_in_yMaximum element size in the Y direction. This can be specified once for all 'dy' intervals or specified for each interval. 'iy' is then determined using the ceiling of dy/size
Controllable:No
Description:Maximum element size in the Y direction. This can be specified once for all 'dy' intervals or specified for each interval. 'iy' is then determined using the ceiling of dy/size
- max_sizes_in_zMaximum element size in the Z direction. This can be specified once for all 'dz' intervals or specified for each interval. 'iz' is then determined using the ceiling of dz/size
Controllable:No
Description:Maximum element size in the Z direction. This can be specified once for all 'dz' intervals or specified for each interval. 'iz' is then determined using the ceiling of dz/size
- subdomain_idBlock IDs (default to all zero)
Controllable:No
Description:Block IDs (default to all zero)
Optional Parameters
- enableTrueSet the enabled status of the MooseObject.
Default:True
C++ Type:bool
Controllable:No
Description:Set the enabled status of the MooseObject.
- save_with_nameKeep the mesh from this mesh generator in memory with the name specified
C++ Type:std::string
Controllable:No
Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
- nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
- outputFalseWhether or not to output the mesh file after generating the mesh
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to output the mesh file after generating the mesh
- show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Default:False
C++ Type:bool
Controllable:No
Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
