BoundaryDeletionGenerator
Mesh generator which removes side sets
Input Parameters
  • boundary_namesThe boundaries to be deleted / kept
    C++ Type:std::vector<BoundaryName>
    Unit:(no unit assumed)
    Controllable:No
    Description:The boundaries to be deleted / kept
  • inputThe mesh we want to modify
    C++ Type:MeshGeneratorName
    Controllable:No
    Description:The mesh we want to modify
Required Parameters
  • operationremoveWhether to remove or keep the listed boundaries
    Default:remove
    C++ Type:MooseEnum
    Options:keep, remove
    Controllable:No
    Description:Whether to remove or keep the listed boundaries
Optional Parameters
  • control_tagsAdds user-defined labels for accessing object parameters via control logic.
    C++ Type:std::vector<std::string>
    Controllable:No
    Description:Adds user-defined labels for accessing object parameters via control logic.
  • enableTrueSet the enabled status of the MooseObject.
    Default:True
    C++ Type:bool
    Controllable:No
    Description:Set the enabled status of the MooseObject.
  • save_with_nameKeep the mesh from this mesh generator in memory with the name specified
    C++ Type:std::string
    Controllable:No
    Description:Keep the mesh from this mesh generator in memory with the name specified
Advanced Parameters
  • nemesisFalseWhether or not to output the mesh file in the nemesisformat (only if output = true)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file in the nemesisformat (only if output = true)
  • outputFalseWhether or not to output the mesh file after generating the mesh
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to output the mesh file after generating the mesh
  • show_infoFalseWhether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
    Default:False
    C++ Type:bool
    Controllable:No
    Description:Whether or not to show mesh info after generating the mesh (bounding box, element types, sidesets, nodesets, subdomains, etc)
Debugging Parameters
