Troubleshooting the PETSc and libMesh Install
If you run into problems while building PETSc or libMesh, the issue is almost always at the MOOSE level, and not specific to Cardinal. We recommend posting your problem directly to the MOOSE discussions page or to the MOOSE Slack. Here, we also collect a number of common issues.
Mixing conda environment with the scripts
If you are trying to use PETSc and libMesh from MOOSE's conda environment, you should not try to later switch to using the script approach (contrib/moose/scripts/update_and_rebuild_petsc|libmesh.sh) because the conda packages separately export environment variables that will conflict with your application in the end, if you are trying to provide it with multiple locations of PETSc/libMesh. If you do want to build PETSc and libMesh from the scripts, you should either:
Turn off the conda environment and just use your system's compilers and libraries
Only install the
moose-mpichconda package, or equivalently slim conda package that does not include PETSc/libMesh
PTScotch needs bison installed
When building PETSc, if you get an error like
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
this is referring to the bison GNU package - not the MOOSE application which also happens to be named Bison. To skip PTScotch, re-run the PETSc script with this option:
./contrib/moose/update_and_rebuild_petsc.sh --download-ptscotch=0
